If your needle isn't picking up the bottom thread, lower your needle just a bit. Only the top of the needle head should be up inside the shank.
Testimonial: "The metal part holding the bobbin at the bottom doesn't spin around to pick it up?"
SOURCE: singer sewing machine model 6012 c
hi
i want to know how i put thread in the sewing machine
thank you
SOURCE: Singer Pixie - trouble threading bobbin
look at the bobbin direction. if it dont pick up that way, change the direction
SOURCE: I have a Singer Special Zig Zag Model 418. I can
More than likely you have a broken vertical shaft gear.
When you turn the handwheel you should see the sewing hook moving under the bobbin case.
If not, take it to a sewing repair person and it should cost somewhere around $100 to repair.
SOURCE: threading bobbin for singer 8734
NEW MACHINE, THE NEEDLE WON'T PICK UP THE THREAD. WHAT WRONG?
SOURCE: I have a Singer Touch N Sew Model 636. The
I had a Golden Touch 'N Sew many years ago and as the machine aged and parts became worn, step 4 of this bobbin winding diagram started to become a problem and I had to sometimes try several times before the "tabs" would release. If they did not release, the machine "thought" it was still winding the bobbin and would not sew.
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_2001_touch_tronic_threading_diagram.htm
