Kindle Fire Factory Reset My kindle fire has a Question mark over the battery. Standard fix is to reset to factory defaults as follows: Cog Wheel | More | Settings | Device | Reset to Factory Defaults However, when I select "Reset to Factory Defaults " I get an error message claiming that the battery does not have sufficient charge to perform the reset. Sort of a catch 22. Please help. My battery is fully charged, but the device doesn't know it??
Press and hold the reset button 40 seconds and then press again and see if it helps.
SOURCE: Kindle not charging
This is a common problem with the Kindle. If you are out of the warranty period I would first try a different cable even if the cable you are using works with other devices. If this still does not help try tilting the plug once it is plugged into the Kindle. Someti,eps wrapping the cord under the Kindle will hold the plug at enough of an angle to maintain contact and thereby charge the device. Not ideal but effective and ver cost effective.
Quick Malware Removal in 2 minutes. Free Download (Highly Recommended)
free-malware-removal.sparktrust.com
