Kodak EASYSHARE M1063 Digital Camera Logo
Posted on Apr 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Everytime I set time and date, camera turns off.
When turned back on, it says "date and time have been reset".
Reset date and time again, does same thing. No other functions will work.
  • zigster365 Mar 15, 2016
    Here's the answer! Maybe late, but we can all learn from this. All digital cameras have a small, internal power source that maintains the internal date and time. Freshly charged or new batteries must remain in the camera for at least 24 hours to fully charge this power source.
    If new batteries aren't charged for at least 24 hours, you must reset the date and time every time batteries are changed. After the power source is fully charged, it maintains the date and time under normal use.
    http://support.en.kodak.com/app/answers/...
Anonymous
Level 2:
  • Expert 297 Answers
  • Posted on Apr 20, 2009
Anonymous
Expert
Level 2:
Answers
297
Questions
0
Helped
113512
Points
742
Memory battery present?? (coin type)
3helpful
I have to reset date time etc everytime i turn camera on
If the Date/Time menu appears when the camera power is turned on, the date battery charge is low and the date and time settings have been lost. Please purchase a lithium coin battery (CR1220) and replace it as follows.
1. Confirm that the camera power is turned off.
2. Slide the memory card slot / battery cover lock and open the cover.
3. Hook your nail onto the date battery holder and lightly pull up.
4. Remove the battery holder in the direction indicated by the arrow. a570isbackupbatremove.gif 5. Remove the battery by pulling it up in the direction indicated by the arrow.
a570isbackupbat.gif 6. Insert a new battery with the (-) side facing up.
7. Replace the battery holder and close the memory card slot / battery cover.
8. When the Date/Time menu appears set the date and time.
Date keeps resetting, when camera is turned off
hi, the problem why evrytime you turn on your camera you need to be set the date/time is the capacitor inside of the camera you need to do is replace with new one.it is easy if you now how to repair electronics or if you have knowldege. try to bring to service center and for sure they will charge a minimun charges.
2answers
Camera keeps loosing the time and date settings. When turning the camera on the lens does not open, then a screen asking to set the date and time settings appears - once date reset the camera works...
have you check the settings for time and date have you saved it? You can also try to remove the cam battry for 2 mins. then put it back in then turn on the camera and then after few secs. turn it off, then see if the issue persist.
1helpful
My M863 changes the date intermittently to a random date & if I don't see the date when turning on the camera it dates the pic's incorrectly. Thanks.
hello,
Everytime you removed the battery of your camera, date and time will be reset. You have to set the date and time correctly.
Follow the steps below.
1.Press the Menu button.
2.select the Setup Tab, it has camera w/ tool icon
3.Scroll down until you select Date and Time
4.Press Ok then set the date and time.
Thanks.
Neerak21
Clock always reset to default upon power up
Either the replacement battery was dead or the camera needs to be serviced. If the date/time needs to be reset every time the camera powers up, the camera is not receiving the power it needs from the date battery.
4helpful
Set date and time comes up every time i turn on camera
Try resetting your camera. In picture taking mode press menu. Go to setup, go up to reset, press right arrow, make sure reset is highlighted and press set.
Then TAKE OUT MEMORY CARD. Go back into menu, go to setup, go up to format, press right arrow and highlight format, press set. Input ur date and time again and then power off and back on. If that doesn't help then you have to send into repairs. 800-706-2534 and keep choosing option 2 and they will tell you where to send it.
Date and time will not stay set
Have you changed the CR2016 clock battery? See the picture and sentence at the bottom of the following webpage:
http://www.steves-digicams.com/2003_reviews/a300_pg2.html
It's a common battery, available just about anyplace that sells batteries.
6helpful
5answers
Camera keeps resetting the settings when turned off
Possible solution?
PROCEDURE
1. Initialize the system.
a) Enter the TEST mode.
b) Select "3:ROM UPDATE" and press SET button.
c) Next, select "5:SYSTEM INITIAL" and press SET button.
d) The following message appears.
SYSTEM INITIALIZE
START ...
PUSH OK KEY?
e) Press SET button and System is initialized.
"SUCCESS !" appears on the monitor.
2. Write firmware.
Update the firmware version"
Write the firmware.
If the TEST mode boots automatically, change "USB TCC ON" to "USB TCC OFF".
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
