Ryobi 18v Variable Speed Impact Driver Zrp230 Logo
Anonymous Posted on Aug 31, 2013
Ryobi 18v Lithium cordless impact drill chuck comes loose while drilling
  • Demixl
    Demixl Sep 16, 2019
    Hey dude, listen I've had the same problems before. I had two drills in one Ryobi 18v drill stuck chuck after 2 month in use and second Drill stopped working when hot. I was very upset. I didn't know what to do where to buy drills to keep them from breaking. My brother is a professional Builder he advised me the place https://toolsduty.com/best-tap-die-set/ where are the truly professional tools you can buy. It's been over two years and I've never had a single problem with a drill. In my opinion it is better to buy quality things once than twice substandard.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 31, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
738
Points
Tighten the screw inside were the drill bits or attachments go this is a reverse threaded screw try using lock tight also
5 Related Answers
Anonymous
  • Posted on Apr 11, 2009
SOURCE: Ryobi impact drill compatibility with normal drill bits
Round bits are not compatible with the Ryobi impact drivers. You need the hex shank "quick connect" bits and accessories. There is an adapter available. it is basically a regular style of keyless drill chuck with the quick connect hex shank that should fit right in to your Impact.
fisherman816
fisherman816
  • 68 Answers
  • Posted on Nov 07, 2009
SOURCE: my ryobi 14.4v cordless drill won't turn on. The
The problem is most likely the switch.http://www.ereplacementparts.com/ryobi-cordless-drill-parts-c-7931_8051.html
Anonymous
  • Posted on Jul 10, 2010
SOURCE: my 18v ryobi cordless drill does not hold a drill
Make sure the screw for the chuck (down inside
the chuck) is tight this happened 2 me. Brought it back
2 h/d The clerk played with it and the chuck screw fell out.
They replaced the whole 4 pack instead of just the drill.
FirsLonewolf
Greg Murphy
  • 186 Answers
  • Posted on Aug 30, 2011
SOURCE: My Ryobi 18V cordless drill
This could be caused by several things.
open it all the way and check the claws for damage or something stuck in them
there should be an allen head bolt inside at the base...check to see if this is loose....it is a left hand thread, if it is tight and the problem is damaged claws then take out this allen bolt, tighten a large allen key in jaws (or grab the outside with visegrips) and give it a sharp snap to the right to remove the end and replace it.
Graham
  • 304 Answers
  • Posted on Jun 23, 2012
SOURCE: ryobi 18v drill keyless chuck stuck
Try holding the bit in a vice and gently tap the chuck off of the bit and see it it releases the pressure on the jaws.
easy to fix
with the drill not running
grab the bottom part of the spinning part of the drill nearest the drill's motor.
then
grab the spinning shaft bit nearest the drill bit
pull them apart slightly
when the two parts are pushed together thay lock the chuck
I own a ryobi hammer drill that does the same thing
How do you put the black chuck cover back on
It sounds as thought you have a keyless chuck on your drill. The cover is not meant to come off. You will have to replace the chuck.
Replace chuck on Makita cordless drill
The BTD 140 only has a sleve, spring, washer, clip and 2 balls. If you need to replace the bit holder then it is part of the shaft (324432-0) that comes from inside the gearbox.Cover unscrews from the body.
Ryobi 18v drill keyless chuck stuck
2answers
My 18v ryobi cordless drill does not hold a drill bit even tho i hold and tighten the chuck with my hand. It will hold for a wile but will eventually fall out. Thanks
Abrupt stops can loosen the ratcheting chucks. Before the invention of those chucks we had the ones that required a key. The proper way to tighten them is to alternate between all three position in order to "seat" the jaws on the bit evenly.That all but guaranteed it would not come loose I assume you have a ratcheting "one handed chuck". ther's only one way to tighten them and you don't get the same grabbing force. The only thing I can suggest is to try to eliminate abrupt stops or try cranking it tighter.
Cordless drill question
1/2"
A 24 position clutch controls torque output. 2 speed range gear box for high torque applications. Auxiliary handle with metal depth stop rod. Has an overmold grip handle for added comfort. A Mag Tray holds screws, small bits and hardware, etc. on foot of drill for easy access. 1/2 Ft.' heavy duty keyless chuck for quick and easy bit changes. Removable 2 position level for convenience and accuracy
1helpful
Keyless chuck
You will find a screw inside the chuck that needs to come out first of all but beware that it will be a reverse thread. This is to stop it loosening whilst in use. then you will need to unscrew the chuck but it isn't easy as you have to hold the shaft that the chuck is attatched to. You can sometimes take the chuck off by holding it and pulling the trigger while in reverse. (but they can be stuck fast).
Makita 6405 3/8
according to my breakdown its a drill. do you checked if there is a screw inside the chuck. if there is one remove it by turning clockwise.open the chuck fully & insert allen key 5/16 or 3/8 short side to the chuck.tighten the chuck & wak the allen key with a hammer counter clockwise. do it again if required.putting back together the other way.
Chuck won't tighten
The chuck is held onto the drive shaft via screw located inside the chuck. The screw has reverse threads and sometimes the screw gets loose restrictinhg the chuck tightening. Turn the chuck to loosen and tighten the screw as though you were removing a normal screw. Good luck
Top Ryobi Drills Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
