mine started only forward and only sometime. now both forward and in reverse. all the timemine started only forward and only sometime. now both forward and in reverse. all the time
You can't post conmments that contain an email address.
Linkage to the gear box reqires adjustment, look on top of the gear box and watch the movment from forward to neutral, then watch the movment from neutral to reverse thet should have approxamatly the same amount of movement, if not adjust the link rod.
If you are able to move in reverse but not forward, you need to adjust the levers. First you will need to elevate the rear wheels and set the neutral. This will then allow you to set the levers for proper forward and reverse movements.
very common problem "fast in forward, but slow in reverse" is what I hear at my shop all the time nothing you can do, factory made problem for 80% of mowers these days
You need to check the cable, it is a push pull telescopic style so it is possible to get forward and no reverse, if it was a hydro problem you would not get forward or reverse, there is also timing gears on the forward and reverse pedal, you nee to make sure they have not jumped a tooth as this would reduce movement on the cable at the hydro
Remove the center dust caps from the rear axles, start the tractor up
and put it in gear and observe the axles, if one of them is spinning
freely inside the wheel, you have lost the 1/4" square key that pins
the wheel to the axle. Replace the key and you can go back to mowing. Hope this helped Tim
More than likely the forward clutches are burnt,causing the no forward movement problem.Remove the transmission dipstick and smell the fluid,if it smells like burnt coffee then you need the transmission rebuilt.
