SOURCE: Assembly manual
you can look for the manual at your nearest yamaha factory base showroom or distibutor or dealer near by or if that dose'nt solve this then visit the yamaha motors offical website for your quaries so friend see you soon...
SOURCE: Can one purchase or order the detergent drawer assembly?
You can order this part directly from Sears. Sears has a very good parts dept. and you can order online.
SOURCE: F2 code. Followed listed
There are no wires underneath the rotor - it is just suspended in the cavity. So you cannot do any damage except make scratches around that area. Maybe take a straightened wire coat hanger and insert from the side hole in the filter sump area. You might be able to push the rotor up to an extent and then grab it with pliers.
SOURCE: need assembly manual Body Solid PSM1442XS
Here is the body solid website you can access manual that you need
http://bodysolid.com/Support/Assembly_Manuals.cfm
SOURCE: assembly manual? PLease....
There does not seem to be a manual for this equipment online.
Recommend you send a request direct to the manufacturer using their web inquiry form.
Testimonial: "thank u for the link."
