I suggest that you should remove deck, turn upside down and place straight edge or tight string line over blades from outer edges of deck frame. Use the guide strips to get even measurement. Rotate blades and measure distance from straight edge to tips at both sides. they should be the same. If there is difference from one side to the other, either the blades are bent, or if each blade is same at each end but not aligned in centre (difference in height) then the spindles need packing to make them even. Check that bearings are not loose. If you do not understand this best to take it to service centre.
You haven't given enough information of the problem. The blades themselves wont turn when you try to spin them by hand or they wont turn when you engage them with the lever or the switch?
