I have a washer that overflows only on the large & super capacity settings. The temp is set at cold/cold. I have continuity at the hot & cold solenoids, & at the water level sensor. Any ideas? thanks!
On this model of washer you have 4 separate components that could cause overflowing. The water valve, pressure switch, pressure switch hose & the air dome. If you have to turn the water off to prevent overflowing, I would recommend replacing the water valve. If you can turn the timer off & the water stops overflowing, I would recommend checking the pressure switch, hose & air dome.
Setting the Controls
Use the Suggested Fabric and Cycle Settings guide ~ Select Rinse Temperature.
to help you make the proper selections.
~ Select Wash Spin Speed.
~ Push Cycle Selector knob in and turn clockwise to
your selected wash setting. If you wish to change setting
~ Select Water Level. ~ Pull Cycle Selector knob + START out to start the washer.
SMALL: Washer is less than 1/3 full of clothes.
MEDIUM: Between 1/3 and 1/2 full.
LARGE: Between 1/2 and 2/3 full.
This washer will pretty much take anything you can throw at it. It was a competetor of the Maytag large capacity washers. As long as you follow the loading guide above you are not going to hurt it.
Thanks for choosing FixYa,
Kelly
Ok, thanks for your recommendation. I heard a click when I blew into the switch. Then I pulled the front cover off & refilled the washer on its large capacity setting. With the front cover off, I noticed the water overflowing from what appears to be an overflow pipe. I am thinking the pressure switch is faulty, so I have ordered a new one.
