Hi
We would recommend you contact Phil & Teds directly for assistance STROLLERS BABY PRODUCTS FOR YOUR PARENTING DAY
SOURCE: my phil & ted stroller has been attacked by
YOU CAN'T GET RID OF MOULD BUT YOU CAN CALL FOR NEW MATERIAL AT 905-847-6276 OR TRY THE USED WEB FOR SEATS.
SOURCE: Replacement Parts Phil and Teds Stroller
http://www.shopphilandteds.com/parts
This is the US site for replacement parts for all models.
SOURCE: how do you change the seat position in the twin
At the back of the main seat unit (which will be totally flat at this point) there is a clip at the top and at the bottom, clip these together and the seat will be upright.
I hope this helps.
SOURCE: Stuck in folded position Phil and teds classic stroller
We have a new Phil & Teds Classic -- same problem. Solution #2 worked for us. Pushing down on the black bars while pressing the grey button was the solution. Not sure why this is necessary to make the silver button line up with the grey button, but it is. Engaging the brake did not seem to make any difference.
SOURCE: PROBLEM WITH THE FRONT WHEEL OF PHIL AND TEDS VIBE
Spray it with some synthetic lubricant. I was about to toss my P&T over the bridge until we picked up a can for less than $5 at the local hardware - it rolls good as new. Occasionally (especially after a rainy day) I'll pull the whole front wheel off, wipe down the inside of the tube, and spray both surfaces & allow to dry before replacing.
