SOURCE: Fisher and Paykel
F1 is a flood code meaning excessive amounts of water have collected on the bottom catch basin. If a flood condition is detected, both draws will activate the drain motors and flash F1. Remove the bottom drawer and dry the catch basin.
TURN OFF POWER TO MACHINE
Remove the front panel by removing two "pins". There is one on each
side of the drawer, and they are at the bottom and circular with a
recessed tab - like an inverted slotted screw.
You just pull the tabs straight out. After that you pull the front down and out.
Drawer is removed by depressing the tab on each side and sliding the support guide
back.
Use a towel to remove excess water pooling, then a hair dryer to speed up the evaporation process of the remaining water.
Regards
Richard
The FixYa Team
SOURCE: Fisher and Paykel Double dishdrawer
when you start the unit let it run for a minute then pause it before it starts to fill and check to see if it's drained it's water if not then you have a drain fault cheers. fell free to Chat live if you want me to talk you through it cheers
SOURCE: Fisher & Paykel DD601 top drawer won't start.
Most likely the micro-switch that tells the controller that the drawer is closed is broken. Its a tiny little black switch at the back of the left drawer slide, it had a metal actuator that is prone to breaking.
SOURCE: Fisher Paykel dishwasher drawer won't stop.
Let's go to diagnostic test mode to see if you can retrieve the the actuator hence the tube out.
1- Press Lock button and start/pause key until the display showing up.
2- Press Power to show HO.
3- Press start button to advance the display until you see P2 for draining, if you pass, keep doing it to get it back in a loop.
4- When at P2, press lock to turn on, press a again to turn off.
5- Listen to the sound of the pump. If you hear nothing that means the pump is dead or stuck.
6- The Motor has 2 directions: one for, Rinse and one for Drain. When you done with the diagnostic, press the power button to get out of the mode.
7- If this is the case, unplug the power then remove the rack, the bottom stanless steel plate with holes then take out the rotor to clean up. It is a good design the stator is outside of the tube, so you don't have to worry too much about the complication.
8- Make a note of all the positions so you can put them back the same as they were. Good luck
SOURCE: I have the DD6031 fisher Paykel two drawer
Disconnect the power to the unit for at least 15 minutes to see if you can "reset" the unit.
Mine does exactly this , any ideas...?
