2007-2013 Chevy Silverado M1 Wire Mesh Grille 615821 - Mesh Grilles Logo
Anonymous Posted on Aug 30, 2013
Need door wiring diagram for 2013 Silverado, trying to upgrade exterior mirrors from DL8 to DL3 with power fold.
Michelle Crabbe
Level 2:
  • Expert 72 Answers
  • Posted on Sep 01, 2013
Michelle Crabbe
Expert
Level 2:
Answers
72
Questions
Helped
28849
Points
171
Is your chevy a 2500 or 1500? this information also helps with determining the correct wiring diagram you require.
What is mirror wiring for plugins?
Installing 08 mirrors on 01 Superduty, looking for wiring diagrams ...
www.ford-trucks.com > ... > Super Duty & Heavy Duty
Aug 12, 2008 - Installing 08 mirrors on 01 Superduty, looking for wiring diagrams Super Duty ... 2013-2014 mirror plug pin outs, SUPERDUTY_08, Super Duty ... Power/Heated/Lighted Tow Mirror upgrade...
Jul 24, 2012
F250 Paddle to towing mirror installation
Dec 20, 2010
Towing Mirror Wiring Harness Adaptor
Sep 15, 2010
Towing mirrors
Apr 16, 2010
More results from www.ford-trucks.com
I need help
It sound like to me that the controller for the mirror is going bad
you may want to go to the junk yard and take one out of a wrecked
truck with low miles or one Gathas been tested
HOW CAN I FIX
First thing to check is the control switch. The next thing is the wiring to the door and the last thing would be the mirror itself.
2helpful
I NEED HELP
Since some features work on both mirrors sounds like a faulty control panel.
2007 gmc heated mirror module
Could have a DDS an PDS .depends on what RPO code yours has >
Outside Mirror Description and Operation (with RPO DL3)
Or
Outside Mirror Description and Operation (without RPO DL3)
Without
Heated Outside Rearview Mirror Operation
The REAR DEFOG relay controls the operation of the heated outside rearview mirrors. When rear window defogging is requested, the REAR DEFOG relay is energized and B+ is applied to the supply voltage circuit of the mirror heater element, located in the mirror face. A constant ground is also applied to the mirror face. Current will pass through the mirror heater element, warming the mirror, so long as the rear window defogger is commanded ON.
With
The DDS and PDS control the activation of the mirror heaters. Upon receiving a serial data message indicating a request for heated mirrors, the DDS and PDS, will apply voltage to the mirror heater element supply voltage circuit. The mirror heaters will remain active until a new message is received indicating rear defogger is to be deactivated.
The power mirror system consists of the following components:
• Driver Door Switch (DDS)--An electronic control module with integrated switches and requires programming when replaced
• Passenger Door Switch (PDS)--An electronic control module with integrated switches, requires programming when replaced
• Power Mirror Direction Switch--Integrated into DDS and is a four position momentary switch that provides a signal input to the DDS for up, down, left/extend and right/retract with a mirror switch activation
• Mirror Select Switch--Integrated into DDS and is a three position switch that allows the operator to select the left or right mirror and also a neutral/fold position
• Mirror Extend/Retract Switch--Integrated into DDS and is a two position switch that allows the operator to select the mirror extend or mirror retract position
• Left Outside Power Mirror--Contains both the vertical and horizontal mirror motors
• Right Outside Power Mirror--Contains both the vertical and horizontal mirror motors
• Body Control Module--An electronic control module that requires programming when replaced, serves as the power mode master and is the main message handler
• Horizontal and Vertical Position Sensors, if equipped with memory mirrors--Supplied a 5-volt and low reference by the DDS/PDS and provide a variable voltage signal to the DDS/PDS that is proportional to mirror position
• Folding Mirror Motor, in each of the outside mirrors, if equipped with power fold mirrors--Provides extend and retract movements of the mirror and is serviced as a complete mirror assembly
Your best bet mite be to take to a qualified repair shop , i really don't think you'll be able to do anything with it.
Do you have wiring diagrams so you know which wires to test ,do you know how to do electrical testing ?
The Driver Door Switch (DDS) and Passenger Door Switch (PDS) supply voltage to the outside rearview mirror heater elements upon receipt of a serial data message from the HVAC module indicating that the rear defrost system is active. The door switch supplies B+ through the driver/passenger mirror heating element supply voltage circuit when a request is seen. Ground is applied through the driver/passenger mirror heating low reference circuit.
3answers
2004 ford expedition eddie bower
For the rear window, just need adjuts the both slightly...
Check the next procedure to Power Mirrors...
Diagnosis & Testing
The exterior mirror control switch receives power through circuit SBP12 (GN/RD) and ground through circuit GD143 (BK/VT). The exterior mirror control switch uses circuit CPM23 (GY) as the common circuit for both exterior mirror up/down and right/left movement.
  1. Possible Causes:
    Fuse 12 (7.5A) (SJB) An open in circuits CPM23 (GY), SBP12 (GN/RD) or GD143 (BK/VT A short to ground in circuit CPM23 (GY) A short to voltage in circuit CPM23 (GY) Exterior mirror control switch.
  2. Checking the voltage at the mirror switch:
    Key in OFF position. Disconnect: Exterior Mirror Control Switch C527. Key in ON position. Measure the voltage between ground and exterior mirror control switch C527-1, circuit SBP12 (GN/RD). Voltage should be greater than 10 volts.
  3. If voltage is greater than 10 volts, check that fuse 12 (7.5A) is OK. If OK, REPAIR circuit SBP12 (GN/RD) for an open.
Exterior Mirror Motor Synchronization
NOTE This procedure must be performed any time the power folding mirrors are manually folded in or out, or if the position of the mirror case has been moved without using the mirror control switch.
NOTE If the power folding mirrors are folded or unfolded continuously (6 to 10 cycles), the power lockout feature will disable the system for 2 minutes to prevent damage to the power fold motors. After 2 minutes have elapsed, normal operation will resume.
  1. Set the mirror control switch to the CENTER position.
  2. Use the mirror control switch (press rearward) to automatically cycle the power folding mirrors in and out 4 times.
  3. When an audible popping sound is heard, the power folding mirror motors are synchronized.
    NOTE It may be necessary to cycle the power folding mirrors in or out up to 4 times before they are synchronized.
Removal & Installation
Motor
  1. Before servicing the vehicle, refer to the precautions section.
    NOTE If equipped with power folding mirrors, they must be synchronized any time the mirrors have been folded or unfolded without using the mirror control switch. Refer to synchronization procedure.
  2. Position the exterior mirror glass in a downward position to obtain a gap at the edge of the mirror.
    CAUTION Place a shop towel between the exterior mirror glass and the hand to avoid personal injury in the instance of glass breakage.
  3. Insert a flat-blade screwdriver between the mirror glass tabs and the mounting plate, and rotate to separate the locking tabs from the mounting plate.
  4. Carefully pull the top edge of the glass away from the exterior mirror housing.
    0996b43f802029e0.jpg Fig. Mirror Glass removal shown
  5. If equipped, disconnect the heated mirror electrical connectors and remove the glass.
  6. Remove the 3 exterior mirror motor screws and exterior mirror motor.
  7. Disconnect the electrical connectors.
  8. To install, reverse the removal procedure.
Switch
Expedition Trim Panel Removal
NOTE The door glass must be completely raised.
  1. Remove the window control switch plate.
  2. Remove the door handle bezel.
    WARNING To avoid damage to the door trim panel, lift the door trim panel by pulling directly upward on the armrest to disengage the panel clips.
  3. Remove the two bolts and three screws, and remove the door trim panel.
  4. Remove the finish cover to access the two center screws.
  5. Disconnect the electrical connectors. Navigator Trim Panel Removal
  6. Remove the door handle bezel.
  7. Use service notch.
  8. Remove the two bolts and three screws, and remove the door trim panel.
  9. Disconnect the electrical connectors.
  10. Depress the locking tabs and remove the exterior mirror control switch.
  11. Remove the exterior mirror control switch.
If you dont want waiting more time for the Owners Manual, can check here this choice 2004-Ford-Expedition-Owners-Manual
Hope this help.
2helpful
Electrical power loss to door
this is usually caused by a break in power wire right at the door janb inside of rubber accordian boot
Changing door mirrors on Mitsubishi gto to folding type
Try gtouk.com or 3si.com as it isn't that simple as you need 2 extra wires running to your door and extra relays to control the folding action.
99 explorer drivers side mirror vibrates
are you trting to tighten the mirror glass or the mirror where it attaches to the body? I don't think glass is removable in 99. Only can try to press on glass to seat if unseated. not too hard.
  1. Remove the front door trim panel; refer to Section 501-05 .
  2. go to car-part.com for a used mirror. Page with * is cheapest seller.
  1. Remove the speaker.
    1. Remove the screws.
    1. Disconnect the electrical connector.
  1. Remove the outside rear view mirror (17682).
    1. Disconnect the power mirror wiring clips.
    1. Remove the outside rear view mirror nuts.
    1. Remove the outside rear view mirror.
      • Feed the power mirror wiring through the opening in the front door (20124).
SECTION 501-09: Rear View Mirrors 2001 Explorer/Mountaineer Workshop Manual
REMOVAL AND INSTALLATION Exterior Mirror Glass, 2001 model Removal
NOTE: Exterior mirror glass is serviceable only on vehicles built after July of 2001.
NOTE: Passenger side exterior mirror shown, driver side exterior mirror similar.
All mirrors
  1. Position the glass in the full up position.
  1. Locate the notch at the bottom of the exterior mirror glass.
  1. Release the exterior mirror glass.
    1. Insert a long flat-bladed screwdriver in the notch.
    1. Push the screwdriver into the notch until the glass is released.
Heated mirrors
  1. Position aside the exterior mirror glass.
  1. Disconnect the electrical connectors.
All mirrors
  1. Remove the exterior mirror glass (17K707) passenger side or (17T675) driver side.
Installation
Heated mirrors
  1. Connect the electrical connectors.
All mirrors
  1. Position the exterior mirror glass on the exterior mirror motor.
  1. Place a hand against the back of the exterior mirror housing and a hand flat against the exterior mirror glass. Press the glass in place until fully seated.
Top Smittybilt Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Smittybilt Vehicle Part and Accessory Expert? Answer questions, earn points and help others
