Question about Canon PowerShot SD780 IS / IXUS 100 IS Digital Camera
Cleaning inside lens - Canon PowerShot SD780 IS / IXUS 100 IS Digital Camera
Hello. My name is Nora. I have dirt and/or condensation on the inside of the lens. How do I clean it?
On the inside of the lens... that requires a professional...
is it near the front of the lens...
...ALL camera lens should have a less expensive "filter" on the front to protect the main lens.....
... make sure your protector filter has not let some "stuff" in...if you have one.. just carefully take it off.. be careful cleaning it!!
how to clean camera lens Google Search
Aug 21, 2017 | Cameras
How can i clean the inside of the lens as there is dust on the inside
Hi Pat, normally dust inside a lens will not affect the image quality. If it does , then really it needs to go to a service centre to be striped down and cleaned. I would imagine this is a zoom lens, as the moving parts in a zoom lens can cause dust to enter the lens.
May 18, 2016 | Cameras
Is it possible to clean INSIDE the lens of Jason model 192, if so how do u get inside to clean? About what is the model worth?
We don't do the cleaning but if there is a camera place near you they could do it. The lens is held in by a ring that takes a spanner wrench to remove.
Jan 06, 2015 | Optics
How to clean lens on rca projection tv model# p61960 ?
Unless something got spilled inside the TV, I suggest you think otherwise about cleaning inside the TV. You will only make things worse by doing so.
Aug 21, 2014 | Televison & Video
I have the quantaray lens ld 70-300mm. Was working fine until one day. When I look through it everything looks slightly foggy. Adjusting it doesn't help. Cleaned the outside lens. Would like to kn
Yes, the lens can be disassembled and cleaned. But before you think about doing so, think about this. Do you have a lens collimator and other equipment necessary to ensure proper alignment on reassembly? If you don't, please leave inside cleaning to a trained professional.
Dec 05, 2012 | Cameras
There is dust inside the lens. how do I clean the dust from inside the lens?
Your projector needs little maintenance. The only thing you need to do on a regular basis is
to keep the lens clean.
Never remove any parts of the projector except the lamp. Contact your dealer if other parts
need replacing.
Cleaning the lens
Clean the lens whenever you notice dirt or dust on the surface.
• Use a canister of compressed air to remove dust.
• If there is dirt or smears, use lens-cleaning paper or moisten a soft cloth with lens cleaner
and gently wipe the lens surface.
Never rub the lens with abrasive materials.
Nov 27, 2010 | BenQ MP623 DLP Projector
How can I clean the INSIDE of a Panasonic Lumix DMC-LZ7 lens?
Unscrew the entire lens assembly from the body. The inner lens cannot get debris inside it but the outside of it and the inside of the protector lens can. It's a good idea to do this cleaning in your bathroom with the shower on hot but not visibly steamy as this will cut the airborne dust by 90%.
Feb 22, 2010 | Panasonic Lumix DMC-LZ7 Digital Camera
How to clean the lens from the inside
you can purchase lens cleaner Cd from market but best way to remove your CD rom cover and clean the lenz manually with lenz cleaner liquid are available in market or just use tissue paper.
Dec 06, 2009 | InFocus Computers & Internet
Clean dust inside the lenz
Don't. Unless there are some really big specks of dirt inside the lens then they will have no effect at all on picture taking. To prevent the problem getting worse always store your lens with it's front and rear caps on and inside a lens bag. Also make sure that your camera bag is clean and isn't shedding fibres from the inner linings.
Dismantling your lens to clean it is really a job best left to a professional who will then additionally check and clean/lubricate the moving parts inside the lens.
Jul 03, 2009 | Tamron 28-300mm f/3.5-6.3 DI XR for Canon
Cleaning dust and dirt from the lens (inside)
Hi Nutty Prof
You will have to open up the unit by unscrewing the screws at the bottom and taking off the top cover of your PB6100.
Right behind the lens is the Lightengine ( where the dust collects )
Take off the cover of the Lightengine by unscrewing the two screws at the top of it . Then blow out the inside of the light engine with Air in a can ( available from most good PC shops )
and then reassemble.
If the dust particles still show after this ( which I doubt it will ) then you will have to take it to a Service Centre to get cleaned out as you will not be able to reassemble the lens once taken apart - it is a HUGE job !
Thanks for using Fixya and Good Luck !
May 24, 2008 | BenQ PB6100 Multimedia Projector
Canon PowerShot SD780 IS / IXUS 100 IS Digital Camera Logo
73 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
