There is a small white gear that drives the fuser module. It wears out at 30 to 40 thousand pages.
If the sound is a jumping to gringing noise that would be the problem.
That gear jumping will cause the machine to say out of paper,, jam,, give all kinds of problems from things bouncing around.
Probably worn gears for the rollers along the paper path or the gears that mesh with the imaging roller in the toner cartridge. Remove the toner cartridge and reseat it. Also look for any rounding of the gear teeth on any of the rollers while you have to cartridge out.
my washer wouldn't spin or drain and it was a baby sock stuck in the pump! unplug everything and then take the hoses off and look in the pump! hope this helps!
