SOURCE: the cd-rom door not open
Sir,
You have encountered a problem often seeen in LG models. It could have spontaneously generated or as a sideeffect of recent servicing. It is difficult to correct. so an alternative way is use a pin to force open the door.
On the front panel there will be a small mm hole through which insert a straightened paper slip to force eject the door. once door is out a little. pull it or use button to fully take out the tray.
For future, always keep a cd rom inside. that will probably let you eject the tray automatically. Problem occurs usually only withthe empty tray. good luck
SOURCE: cd rom door can't be opened
When U Insert A Pin Into the hole. does u feel that the pin is pressing some kind of pully? or anything?
if it
SOURCE: Windowa Viata is not detecting the CD ROM . CD ROM
If this is a laptop then you might need a 5amp power adpater. or get a double USB cable to provide enough power for the drive.
