Re: Lost power Cord to T.V., All I have is a monitor....
Try ordering a replacement from memorex through there web site, or any major electronics store might have a universal cord that could work with your tv. Be prepared to pay , alot. $80 -$120 . I had to replace my power cord for my panasonic lcd tv. cost was $110
There is a monitor connection on the back of the pc, next to the ac adapter connector. Just plug in your monitor to it and make sure you plug the monitor's power cord into an electrical wall outlet.
The speakers wires are normally color coded if the computer isn't ancient, the Speaker PLUG is green, if you are using the speakers in the monitor, then plug the green one from monitor to green jack on back of PC, (Microphone plug and jack is pink/Red).
If you are using other speakers 3rd party, 4.1,5.1, the hookup is different usually, But I think you need green to green, there should only be one green plug on back of PC, It may be labled sound out. but yours is probably green.
PS you also need to kake sure the monitor speakers dont require their own Power Supply/ AC adapter, Most of them do, while some desktop and monitor speakers do not just connect the cord ffrom monitor to green jack, "sound out". If this helps, thanks for the feedback
Your description is the external power supply/adapter for a Mag Innovision LT776s 17 in. Flat Panel LCD Monitor. One may be purchased here. Aftermarket/replacements may be found here, here or here. Pls verify that the plug matches the jack and the polarity is correct. Additionally, if it would be a replacement, pls check the voltage and current rating.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
I purchased a HP Pavillion Slimline computer that was accompanied by and HP flat screen monitor: HPw1858. My problem is that the power cord is missing. Can you help me locate somewhere I can purchase this cord?
