Konica Minolta bizhub C250 All-In-One Laser Printer Logo
Posted on Apr 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
C0501 DEVELOP ENIO210
Konica Minolta Error Codes and Solutions
Level 2:
  • Expert 210 Answers
  • Posted on Sep 03, 2009
Expert
Level 2:
Answers
210
Questions
0
Helped
153679
Points
393
FUSING ERROR ISSUES
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Good Morning, my Konica Minolta 7220 is showing error C0500
Error code C0500 and C0501 means Fixing unit's temperature abnormality.
How to reset these codes?
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
http://servicekonicaminolta.blogspot.com/2012/03/error-code-c0500-and-c0501.html
HOW TO SOLVE ERROR CODE C0500 FOR KONICA MINOLTA 211
C0501
The 501 code is not for bizhub 350 is for dialta 250/350/2510 and refer to fusing unit error.
2helpful
I have a Konica Minolta bizhub D2510F it gives me this error C0501. after searching around I found out that this error is a Fuser error. I replaced the Fuser and the PhotoConductor but I still get the same...
The error has to be manually reset. Here is what I found from the official procedure. Hope it works. How to clear a fuser error code (C0500, C0501, C0510, C0511, C0520, C0521). Solution To clear the fuser error code, perform the following after correcting the cause:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
Note: It is not in the same location as the models 7915/7920.
2. Insert a suitable object into the hole to actuate the reset switch .3. The code should clear and a message to close the front door should appear.
2answers
C0500
The problem is in the fusing unit.Clean or change the unit components,heater lamp,thermitors,thermofusese.
5helpful
C0501
turn off the machine, press the stop button, turn the machine ON, and keep the "STOP" button pressed, C0501 error code will reset in few moments...............
13helpful
My bizhub has an error code of C0501
C0501 it is a trouble related with the Fusing Unit. Try to power it up with the STOP button pressed. If not, you may need to change your fusing unit.
2answers
After a power surge it comes up with a C0501 malfunction code and shuts itself down
The C501 code is to do with the fuser section not heating up in a given period of time.
Best guess would be that the surge blew the thermal fuse in the fuser and the lamp in not coming on.
This will nivolve taking the fuser apart, if you are not so inclined, it might be time to Call your local Tech.
4helpful
2answers
Error Code C-2152
if you interested for complete service manual downolad at www.eserviceinfo.com
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
