Hello
Ensure
the Frigidaire dishwashing machine is fully connected to a power
supply. Shut the dishwasher door firmly and select a wash cycle. Press
"Start" to begin. Check that the "delay start" option was not selected.
Verify
that dishwashing detergent is placed in the dispenser and choose a
longer washing cycle for heavily soiled items. Do not overload the
dishwasher, as this may prevent proper cleaning.
Check
the household water pressure, which should be between 20 and 120 PSI
(pounds per square inch). A water pressure gauge can be obtained at
most home repair stores or hardware stores.
Turn
on the hot water at the sink closest to the dishwasher prior to
starting the dishwasher to raise the water temperature inside the
dishwasher. Check the hot water temperature, which should be at least
120 degrees Fahrenheit for proper cleaning.
5
Check
the spray arms in the dishwasher and move dishes that may be blocking
the water spray or preventing the spray arms from rotating properly.
Read more:
Frigidaire Dishwasher Wash Cycle is Not Working ' eHow.com http://www.ehow.com/how_7877923_frigidaire-wash-cycle-not-working.html#ixzz1Xow3qbbvVerify that dishwashing detergent is placed in the dispenser and choose a longer washing cycle for heavily soiled items. Do not overload the dishwasher, as this may prevent proper cleaning.
Check the household water pressure, which should be between 20 and 120 PSI (pounds per square inch). A water pressure gauge can be obtained at most home repair stores or hardware stores.
Turn on the hot water at the sink closest to the dishwasher prior to starting the dishwasher to raise the water temperature inside the dishwasher. Check the hot water temperature, which should be at least 120 degrees Fahrenheit for proper cleaning.
Check the spray arms in the dishwasher and move dishes that may be blocking the water spray or preventing the spray arms from rotating properly.
water comes out of top outlet intermittent
