THIS MOTHERBOARD BEGAN ITS TROUBLES BY REBOOTING ON ITS OUN WHENEVER IT DEEMED SO. NOW IT JUST WONT BOOT, ITS STUCK ON THE "QDI" LOGO.
CAN ANYONE HELP, IS IT SALVAGABLE??
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cables
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
make sure there are no disks in cd floppy usb drives
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
if its a flat ribbon 40 pin IDE it will be the fist to fail
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs data and power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
also make sure you have set it boot from you hard drive in BIOS
hope this helps
HI
THERE ARE NO LEAKNG CAPACITORES. IN THE VERY START OF THE BOOT SEQUENCE, A QDI LOGO APEARS. AND THATS WHERE THE PC REMAINS.
Did you check the motherboard for any leaking capacitors?
