Try a hard reset to this set first. If it do not help you; check and replace the main system control memory IC. it is faulty.
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Plug your PS3 on either TV. Turn on the backswitch. When the red light in front is on, put your finger on the on/off button in front AND KEEP IT THERE. You will hear some beeps; don't worry about that. Keep your finger on the button until the front power light goes red again. This resets the PS3 video settings. Turn the PS3 on and the TV should pick up the signal.
Unplug tv and cables or satalites boxes,replug both back like an hour later.Now the tv it resetting itself back to factory setting.The cables or satalites boxes is resetting and it upgrading it softwares.The tv should work now.
Tries unplug the tv for an hour,replug it back in.Go to tv Menu,go to PICTURE,go down to resetting.The tv Tuner board should resetting it back to Factorry setting.All the HDMI setting should work now.Not,than than the Tuner board is dead.Tries websites like Shopjimmy.com Ebay.com to buy a refurbish Tuner board for the replacement.
Hi - the tv sound will be picked up like an fm radio signal at 83 mhz. To get there, press the reset button the side of the headphones, then press scan. the first signal to be picked up will be the tv signal. This assumes, of course that you have fresh batteries in the transmitter and headphones, and that the volume is turned up on the headphones and the TV. Worked for me. The signal is not stereo, though.
