Make sure that the DVD Disc is of the format that your DVD recorder can read. For example, if your recorder specifically requires a DVD -R type disk, it will puke on a DVD +R disk.
Usually means the lens needs cleaning. Occasionally, it's a case of the drive binding. Try running a lens cleaner through it first. You'll want the type that's got optical quality brushes built in to the bottom of the disk.
If that doesn't fix it, it's likely a drive issue, which means it's time for replacing the unit - costs more to fix than replace.
it might be sevral reasons:
1. Check if region code is the same for movies you playing and DVD player
2. If you using video CDs or copyed DVDs, player might be preventing to playback those kind of discs, due to copyright laws or due to different speed settings for DVD player and discks you using (for intsrance you player can playback DVD/CD+R, and you using DVD/CD-R, or mximum allowed playback speed is 16 you using disk recorded at 24, but this is in case you using burned/copied CD/DVDs)
3. Check it lens is durty. For that use CD/DVD lens cleaning disk
($6 in Walmart, if you are in US)
4. Check if movies you are have the same coloring system, i.e NTSC for US
5. Check CD/DVD for scratches, some DVD players can not playback scratched disks
Please kindly let me know if my information was helpfull for you or you need more info
Good Luck
If these disks have not been finialized then they will not play on the dvd player. Turn your computer on and see if they will play. If they will then you will need to the dvd palyer finialize them. I hope this helps you. If not get back to me and then we can try a different way.
Place a disc in the tray with the label facing up. Let it try to read. If the disc is still oriented the same way after it fails, odds are 99 out of 100 the motor has failed....sorry, buy a new one if warrantee has run out.
You may have had a brief power outage you did not know about. Then the DVD player needs to be unplugged from the wall and started up again or your lens may need to be cleaned
Because your dvd player is only made to play region 1 discs and vcd's are region 2. You need to buy a dvd player which will play all region discs or is rated region 0 which is the same.
www.dvdenergy.com/index.htm
wont play dvds says
disk error
--please eject disk--
playback feature may not be available on this disk
tried different disks
still the same
