Hello Hilda, thank you for your post!
There could be a number of
any one of several underlying causes in why the oven is experiencing this
particular issue:
·Convection
heating element
·Thermal cutout
·Thermal oven
sensor
·EOC
(electronic oven control)
·Ignitor,
·Bake or broil
element
·All wired
connections
·Lastly the oven cavity and insulation should be checked to ensure there are no gaps or damages that will leak out the heat.
The parts above will need to be assessed for further evaluation by a technician since it is always a good idea to get the appropriate diagnosis prior to making any unnecessary part replacements.
SOURCE: How to lite a pilot lite on a frigidaire "Gallery" gas stove?
wet sparkers, let them dry out good
SOURCE: frigdaire gallery stove
lock mechanism is acting up. happens sometimes. you can get to it from the back and get the thing open to use until you get the part
SOURCE: Frigidaire Range - Oven does not work
If your ignitor looks real dull orange then that is what is wrong. It needs to be bright as the sun or it is weak.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: I have a frigidaire gallery stove. The bake not working
Your oven ignitor has gone out. This is located under the pan in the bottom of the oven. This is held in with 2 screws in the back portion of the pan. This will expose the ignitor and then 2 screws take it out. Replace this and this will fix it. very common problem
SOURCE: Frigidaire FGF316WGSF GAS range oven won't work.
check this out
