Compressor runs. Replaced regulator. Tank will not build up pressure past 25 lbs.
IS YOUR AIR FILTER CLOGGED. SOUNDS LIKE THE VALVES IN YOUR HEAD ARE NOT CLOSING ALL THE WAY. THEY ARE MOST LIKELY REED VALVES, THIN STRIPS OF METAL THAT OPEN AND CLOSE WHEN THE PISTON MOVES. MAKE SURE THEY ARE CLOSING ALL THE WAY (NOT CARBONED UP). DID YOU REMOVE THE HEAD AND DID YOU PUT BACK LIKE YOU FOUND IT - NOT TURNED OR FLIPPED OVER. SEE IF YOUR FINGER WILL GET SUCKED UP TO THE INTAKE HOLE.
