Have a pioneer TS-3001D4 sub, Can i hook just one of these to mono kenwoo amp or do i have to hook up two?
No, the sub is dual 4ohms...meaning if you parallel the positive speaker terminals and the negative speaker terminals you will have a 2ohm sub. Conversely, if you series the pos and neg you will have an 8ohm sub. if you wirte to just one set of terminals on the sub you will have a 4ohm sub.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
you have it, wire it parallel for max output ( parallel means both POS terms on sub connected together and connected to the POS output on the amp...likewise with the NEGs.
Yes, you can. Verify that your amp is 1ohm stable and that you have adequate power supply (i.e. alternator, batteries,capacitor or power cell, etc.) A 1 ohm sub will draw maximum output from your amp, so make sure you have enough input power. If you desire a lot of thump, 1 ohm is great, however if you want deep, rich full bass ( and listen to artists who play real music), then 2ohm or higher is prefferable.
what would be the optimal speaker/s for this amp?
would a 2 ohm dual voice coil speaker be better? can i run it paralell at 1 ohm?
