SOURCE: Need a 1972 Honda XL 250 that needs a kick starter Shaft
you will have to find the same model, there were no xr back then
SOURCE: where exactliy is located the air-fuel mixture
The pilot air screws are sealed to prevent tampering. If access is necessary, the plugs can be removed. The Clymer manual, number 314-3, gives a detailed procedure, with pictures. Be careful! This requires skill with a drill in a small space, and it is possible to destroy a carburetor with poor technique.
Good Luck!
SOURCE: Where at the air fuel mixture screw located on a Honda 94 600 f2 carberater
It is sealed with epoxy, it is on the side above the float bowl
