SOURCE: konica minolta bizhub C252 printer Problem
Is anyone else having problems getting Konica to stand behind its products.
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
SOURCE: konica minolta bizhub 200 c2557. Help please!
c-2557= ATDC Sensor abnormality to reset go to service mode, to enter service mode perform these steps, 1-press utility/counter button from the panel, 2-press check details, and press "STOP" 0,0, STOP 0,1 3-now you are in service mode, 4-click on tech rep mode,or Adjustment 5-now click on "Printer" 6-here increase the value, suppose you have 150, make it 170, press the clear button to clear it and enter new value which should be more than the previous one. press enter and exit from the service mode.
