Motorola Mobility W510  Mobile Phone Logo
A
Anonymous Posted on Aug 29, 2013
Binatone mobile- try to send text but message comes up"Failed"
Cant send text messages
call your service provider they will send you a setup message for your mobile including the message center
I cannot send texts, it comes up with "Message Sending Failed, check details" any clues?
try to switch off your mobile phone then turn it on again or if it does'nt ok try to change your sim card.
Why am I unable to text on my binatone mobile phone when I try to send a text message to someone it reads 'please wait'.
It should say "Please Wait" briefly, if it does for any length of time it may be worth contacting your network provider. If it still doesn't work call Binatone Helpline on 0845 345 9677.
2answers
Nokia 1112 cannot send text messages but can receive
You cannot send messages because the message centre number stored in your mobile may be wrong.
Please enter the correct message centre number. To get the correct message centre number please call your service provider and they will provide you the number.
Menu > Messaging >Options >Settings > Text message >Message centres
Thank You
1helpful
When I go to send the picture in a text message a box comes up and says the I need to enable my mobile settings I have tried to change everything in my mobile settings and get the same message every time.
Once you dump a picture inside a text message that becomes picture message or mms. Hence, you can't directly send the mms through your mobile without getting settings from your service provider call your service provider and ask them to send mms settings to you and then you can send picture messages. Caution mms messages are costlier than text messages.
Jun 13, 2010 • Cell Phones
I was texting fine now can't send text but can get them
you should check it with your mobile service, because if the message is being barred it's because your network is not allowing you to send it, must not be a problem with the cell phone .
else, try resetting your iPhone (hold both the upside and the circle button for a while) or restoring it in iTunes .
I get a failed message when I try sending a text
It may the Message Centre has been set up incorrectly or changed from your service provider.
Check the number you have by going to Text/ Options/ Settings/ Message Centre.
If this isn't as it should be or changed - Check with your Mobile Network the correct number along with the prefix codes.
4helpful
3answers
Message sending failed, number not in use..
call customer care and ask them for message center number n how to put it in yor mobile model.they will assist you. If its not working goto settings and do a restore to factory settings.then it ll work fine.But this ll erase any contacts calnder entries etc etc.so mk a note for al thse before you do this.
Feb 11, 2009 • Nokia 1100
4helpful
Text messaging
Check the message center no .. it might me wrong !!! Call ur customer care and verify the message centre no!!
May 22, 2008 • Cell Phones
Sending text message failed
i'm not sure but this might be due to the non-removal of undelivered text messages from the sent items... plss do check,,...
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
