I have recently had to have my computer rebuilt do to having some bad viruses. When I went to reinstall all of my software I could not find my installation CD for my Canon Rebel XT. I can't figure out how to load my photos onto my computer without the EOS Utility software. I hook up the camera and turn on the computer and it doesn't do anything at all. I loaded the driver off of the Canon website but that didn't fix the problem.
Please help! Thanks!!!
I have created an ISO image of my Canon 350D software CD and uploaded it to filefactory.com
You can download it here http://www.filefactory.com/file/aga8gc6/n/EOSv10_zip
You should be able to get a free download slot, keep trying if the server is busy.
If you do not have software which can extract the ISO file, try the excellent CDBurnerXP, completely free from http://cdburnerxp.se
Once you have burned this to a CD, just insert and the Canon installer menu should automatically appear.
Please take the the time to rate this solution.
SOURCE: Canon EOS/Rebel XT won't power up
Joe, this happened to me, just tonight... I got a new CF card and stuck it in, turned it on and one CF card flash. Completely dead from there. I found one of the CF card pins bent over, shorted out the socket and blew the mainboard fuse. I took the camera apart, found the fuse (labelled K) about under the set button area) I bridged the fuse with a bit of solder, straightened out the pin in the socket, put it all back together and it's working fine. The fuse is under the right side shield cover, it's labelled with a letter K. There is another fuse on the power inlet board (below the shutter button) and it's labelled 'P'...
