SOURCE: swiss army watch
Did you have the battery checked to see if it was bad a first? Take it to a Reputable watchrepair , and ask them to CHECK your battery NOT replace it. Alot of times your watch will have a mechanical problem which will make your watch look like it is o.k. once you replace the battery but, two weeks later the watch stops again because the battery has lost enough power to now stop the watch again. Also your watch may have a electrical problem which a battery will not solve the problem. The coil (the orange straight piece in the movement), or the curcit board could be bad. Always have the store check your battery because, if you ask them to change your battety they will no matter if your original battery is good or not.
SOURCE: Replacing battery on wenger swiss watch
Hate to say it but Wal-mart has the tools; seems like they'll do it for free if you buy the battery
SOURCE: how to take links out of the band of a wenger
Save yourself the time and frustration and take it to a reputable watch repair shop and let them adjust your band for you. Could be screws or could be pins! Plus if anything small drops you might not find it again!
SOURCE: How to remove the back cover of the swiss army
The back will either have a small slot on one edge to pry it off or indentations around the perimeter for a case wrench to unscrew it. Specialized tools are used to avoid scratching the case. You best bet is to take it to a watch shop and let them do it. Most places charge between $3 - $8 to properly do it without damaging the case and they should also change the gasket to maintain water resistance if so equipped. Once you have it open you risk damaging the movement as you change the battery. It's not that it's a tricky procedure but you can easily damage something that will cost a LOT more than $8 to fix if you don't have experience.
good day,
hope this link below will solve your problem.
watches
