A
Anonymous Posted on Aug 28, 2013
I'm trying to import DSS files and convert to WAV. I keep getting the "Unexpected error has occurred. Contact your Oympus dealer" error message. I have verified that the arial.ttf is installed correctly. I don't know what else to look at. Thank you.
2 Related Answers
tscmusa
Mitch Davis
  • 95 Answers
  • Posted on Mar 26, 2010
SOURCE: .dss NOT .wav
DSS is proprietary to olympus,however if it records in .wav it wont work unless you buy a file conversion program
tscmusa
Mitch Davis
  • 95 Answers
  • Posted on Mar 30, 2010
SOURCE: Olympus DW 90 VN series. I have been using the
get switch audio converter software from www.nch.com.au
works for us like a charm
2answers
Olympus DSS Player Pro Woes!
Could it be that the files are just being regularly accessed by one of the server admin tools and the DSS Player application interprets an open file as 'being transcribed'
What happens when a copy of a .DSS file is made to an operators machine and then loaded locally for transcription?
3helpful
2answers
I cant' read a WAV file with the Zen V plus I
try and convert your wav files to mp3 or wma whatever you prefer just google wav to mp3 converter that will ensure that your player will read it
6helpful
2answers
Voice Recorder-Files to CD?
Please follow the below solutions to create either an audio CD-ROM of .wav files or back-up
.wav files to a CD-ROM.
Problem: .Wav files downloaded to PC computer from the DW-90, VN Series, and DSS Files
created with DS Series recorders cannot be copied to a rewritable CD-ROM using Windows
Media Player to create an audio CD-ROM.
Explanation: These digital voice recorders create .wav files at 8kHZ, 12kHZ, or 22kHz
depending on the Quality setting. Digital Wave player software is used to download Wav files to
a PC computer from the DW or VN Series of recorders. DSS Player is used to download DSS
files from the DS Series recorders and convert them to Wav files. If Windows Media Player is
then used to copy the files to a rewritable CD-ROM to create an audio CD-ROM, the files will
not copy properly or an error message may appear. Windows Media Player can only create an
audio CD-ROM if the .wav file is 44.1kHZ, 16 bit stereo.
Solution: Follow the procedure below to convert the .wav files to 44.1 kHZ, 16 bit stereo. Then
use Windows Media Player to copy the files to a rewritable CD-ROM.
1. Click Start, click All Programs, click Accessories, click Entertainment, and then click Sound Recorder.
2. On the File menu, click Open.
3. In the Open dialog box, specify the name of the audio file that you want to convert, and
then click OK. Files are usually located at C:\Program Files\Olympus\Digital Wave
Player\Message\Folder A.
4. On the File menu, click Save As.
In the Save As dialog box, click Change.
In the Attributes box, click 44.100 kHz, 16 Bit, Stereo, and then click OK.
Click Save. After you convert your files, try to copy them to a CD-ROM again.
Windows Error Recovery - ''an unexpected I/O error occured''
Hi
This seems to be serious problem. Please share the exact error message. If there are any external devices connected to the system please remove and then try to boot the system again.
Also post the brand and model of your laptop so that we can be more specific in terms of the steps.
Thank you
Rakesh
Dell Expert.
Converting wma files to wav files on olympus DDS player version 7
When using the DSS Player v7 software the program is unable to convert WMA to WAV. The option you see there only works when it is a .dss file that needs to be converted to .wav. In order to convert WMA to WAV you will need to locate a third party software program that does this type of conversion.
Go to google and search on WMA to WAV conversion editors.
Top Olympus Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Ngoro
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
