Jerry, Drive to a good shop. So many things can cause reduced power light unfortunately. The first step would be to get the truck hooked up to a scanner/computer and have the computer scanned for trouble codes. One thing that you could try is to drain the water from the water separator that is mounted on the frame under drivers front door. If the PCM picks up on water, power is reduced until water is removed/drained. It could be an exhaust sensor that is reading faulty. Unfortunately from here its impossible to tell you exactly what the fault is because there are just so many engine sensor inputs that could cause your problem. Check the attached links, forums,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Reduced Engine Power Light Wrench Showing Ford Powerstroke Diesel Forum
08 Reduced Engine Power
Regen Reduced Engine Power Light Ford Truck Enthusiasts Forums
Help reduced engine power light comes on
