My freezer intermittently shows a high temp alarm and keeps running even though its still cooling well and gets down to -13F. I changed the thermistor, but it's still doing it. What else could it be? The electronic control?
Hello David, thank you for your question! Based on the symptoms you are describing, it sounds like the issue may be related to a possible wiring failure between the thermistor and control or the control itself is faulty. At this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
SOURCE: Freezer will Not Go Below 8 degrees and Alarm keeps sounding
Our manual says it can take our freezer up to 48 hours to get back to the correct temperature. I found that to be the case when we loaded it fully for the first time.
SOURCE: Frigidaire stand up frost proof w/ temp alarm /
If your compressor is running with no freon, It should be very hot. Check if it is. And if it is and the freon has leaked out. Then you must find the leak in the system before you add more freon. If you dont this will be an ongoing problem. The freon will leak out after any length of time. This is a very hard task to find the leak, and you will be money ahead to buy another if you dont find the leak than to re charge every year or so.
SOURCE: I have a frigidair chest freezer...gets cold..and
yes the ambient temp has alot to do with the operation of the freezer.there may also be a issue with the temp control.
SOURCE: deluxe electronic control alarm on
Hi, Freezer alarms indicate two things: The door is not closed correctly; The temperature is warmer than -12 degrees. The alarm can be visual ( red warning light), in either case it can happen if you have just filled your freezer with loads of fresh unfrozen food, however the alarm should self cancel after approx 20 mins as the freezer chills the fresh food and the warm air, down. A persistent alarm should be investigated by a fridge engineer as soon as possible, any food defrosting below -8 degrees is definitely suspect as far as refreezing is concerned. Where a failed thermostat causes the alarm the food will totally defrost, where a gas system is inefficient it's possible to have an intermittent alarm. The freezer should maintain a temperature between 0-5 degrees and if it gets above 15 degrees, the alarm will sound. This could be a thermostat problem, if it's keeping the compressor off too long. If the compressor is not running and it's warm inside the cabinet, turn the thermostat to a colder setting. If the compressor comes on, the thermostat will need to be replaced. If the compressor still won't run, check if it's hot but be careful. If the compressor is hot, the problem can be with the start kit or the compressor has failed. Another possibility is if the compressor is running but there is not a full frost pattern on all the shelves, it indicates problem in the seal system. Whichever cause happens, it will need a thorough checkup and repair by an engineer. Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
SOURCE: Frigidaire 20 cu ft. upright
Is your compressor kicking on? If not then check the contactor-relay and the capacitor. If that isn't the problem then it is probably your compressor. Which is quite expensive to replace.
Thank you for your post, friend!
I see your Frigidaire refrigerator is not cooling and you have performed a reset on your appliance by unplugging it. You could be experiencing an issue within your control panel or sealed system. I would recommend seeking assistance from a professional to come and diagnose your appliance for the proper repair. Hopefully this is helpful. -Matt
