Computers & Internet Logo
Anonymous Posted on Aug 29, 2013
Kernel missing corrupt
I just need to no the scannow command in the cmd
Ashwinee Pareek
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 99 Answers
  • Posted on Nov 06, 2013
Ashwinee Pareek
Expert
Level 2:
New Friend:
Night Owl:
Answers
99
Questions
0
Helped
9854
Points
241
Run chkddsk at command prompt
My cut and paste feature does not work on my windows 2007
if you are an administrator do the following open up a command prompt
1.click start
2.type cmd
3.before opening cmd right click and run as admin
4.on the cmd type> sfc scannow
5.this command looks through your windows system and repairs corrupt files and some windows registry keys. hope it helps
6. this tool is very simple once its done it will ask you to reboot the pc .. reboot the pc and you should be clear
1helpful
Error code Ox80092003 on vista pc
Run System File Checker (SFC) to check if Windows Vista system files are corrupted.
1. Click Start, type "cmd" (without the quote) in the Start Search bar, right-click cmd.exe and click run as administrator.
2. Input the following commands and press Enter after each line.
sfc /scannow
Note: There is a SPACE between "SFC" and "/Scannow". This command will take several minutes to complete.
Restart the computer.
I have a laptop that is a Compaq Presario and upon start up it says the following a kernel file is missing from the disk Insert a system diskette and restart the system how do I fix this
Which kernel file are you missing?
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following commands and press enter after each one:
sfc /scannow
chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
"windows explorer has stopped working"
Try using System File Checker to scan your OS for missing/corrupt files, complete these steps:
  1. Click Start, and then type cmd in the Start Search box.
  2. In the results area, right-click cmd.exe, and then click Run as administrator. You will be prompted to type the password for an administrator account. Click Continue if you are the administrator or type the administrator password. Then, click Continue.
  3. At the command prompt, type Sfc /scannow, and then press ENTER.
The scan may take some time, so be patient. Windows will repair any corrupted or missing files that it finds. If information from the installation CD is needed to repair the problem, you may be prompted to insert your Windows Vista CD.
My Compaq win32 is too slow and whenever i download it will corrupt the file?
Insert operating system disk in drive.
Click Start. Click Run. Type
cmd
Hit Enter.
type in command prompt
sfc /scannow
Hit Enter
System file checker will replace the missing files. download registry cleaner reg in out to clean registry and to fix the error
1helpful
Firma problema: Nome evento problema: APPCRASH Nome applicazione: YahooMessenger.exe Versione applicazione: 10.0.0.1270 Timestamp applicazione: 4c053ffe Nome modulo con errori: ntdll.dll ...
Re: appcrash
Vista
Go to Start > Type in .....cmd........right-click on cmd and select "Run as administrator".
After the cursor paste in : SFC /SCANNOW and press your 'Enter' key.
This procedure will scan Vista's protected system files
and attempt to repair or replace missing or corrupt files.
XP
Use the Administrator account
Go to Start > Run - Type in ....cmd.... > OK.
This procedure will scan XP's protected system files
If the result shows that the corrupt files are unable to be repaired, go for a 'banket' repair using Yahoo Messenger Help
http://help.yahoo.com/kb/index?page=content&id=SLN371&actp=search&viewlocale=en_US&searchid=1283483848357&y=PROD_MSNG_MSNG10
1helpful
2answers
APPCRASH in yahoo messenger
Don't be too worried is a technical problem it will solve by yahoo team of engineers.
My windows launcher has stopped working
Hope this helps you. Let us know either way. Make it a great day!
And Thanks.
Error 0x80070002
This error code means that a file that initializes the component being accessed is corrupt or missing.
Go to Start and type cmd.exe In the results, right click the cmd.exe file and select the Run As Administrator option. In the command dialog, type the following.
sfc /scannow
Press ENTER.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
