SOURCE: with every step I get squeak / chirp while running on treadmill.
Check the knob used to hold it up in the folded position. While running, have someone pull it to the out position. That was the problem on mine. If it is, a little grease on the end of the rod should do it.
SOURCE: Horizon treadmill loud squeaking sound
you need to lubricate the pivot points and deck. Check to make sure the deck is not broken.
