I beleive this is a Hamilton Bathware Garden Jacuzzi tub. We had it installed when our house was built 10 years ago. All of a sudden the start button is sticking. It is currently stuck with the pump on. We had to use the wall turn off switch to turn it off. Is there a quick, and cheap repair to this problem or is it going to be a major fix?
I called a plumber. He said push the button all the way in, put some 3 in 1 oil on the inside (you'll see a little indent) every couple of months. Also push and release the button quickly. Cost me $80, and he even used my oil!!!!
churchill
I have a tube with a push down button on the top right side of the tube that will not work. How dose the switch come out I cannot get to the undside,
Try using some emry cloth on the inside of the button bezel to clear away any calcium that may have built up there. That should solve the problem but if it doesn't, it could be a bad button or the switch on the back of the motor is bad. Start with the emery cloth.
Yes, I have a kolher tub, you'll have to pull the button and it's casing where you will epose the rubber tube, you will notice a black rubber washer that you should replace, I beleive the rubber washer get wet and expands which makes the button stick.
I have same problem, mine is not even three years old, It is the regular size tub with the skirted sides or access to area, looks like maybe air line horse has a kink close to the back connection. I can't get in there without cutting a whole in the wall or do you think it is the button. Any help!
I haven't used my jacuzzi in several years because the start button gets stuck with the pump on. There is no wall switch (the tub is second-hand) and the only way to turn it off is to get out of the tub and pull the plug. Not a good idea when wet! Is it an easy fix?
PR
