When printing from Illustrator CS to an Epson R1800 the image gets enlarged to approximately 103% Epson said to check the default margins but that did not help. I am running a G4 with OS X.5.6 The problem i think started after going from X.4 to X.5. But can't swear to that. I have the latest print driver from epson. Also in Illustrator when when printing there is no plain paper option available. I have re- installed the drivers and ICC profiles but no help. Thank you
Make sure the paper size is not set to US letter sheetfeeder borderless use just US letter. the borderless function slightly enlarges document content to ensure that it bleeds overthe edge. If your has a bleed, use in page setup - US letter sheetfeeder borderless - In the print dialog box click printer button which brings up a warning about using a different settings dialog box, - continue on to the r1800 print dialog box. about midway down is a pull down menu - choose expansion and adjust it to the lowest setting. if your printout does not bleed to the edge bump the expansion adjustment up 1 measure.
