Generac 5622 GP Series GP5000 6,250 Watt 389cc OHV Portable Gas Powered Gen Logo
Posted on Apr 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Generac Generator won't stay running
The generator starts for it's weekly timed maintenance, it starts and runs for about 40 seconds, then stops. Thenit starts again and runs for 30 seconds, and stops, then 20 seconds, etc etc, until it does this for about 5 starting attempts, when it finally stops, and will not stry to start anymore. If I stand by and wait a few minutes, and start it manually, it will start and stay runninn sometimes after a couple of attempts.
The same routine happens if the power goes off, and the generaotr is asked to come on line.
Any ideas?? Charlie
Kenneth
Level 2:
New Friend:
  • Expert 50 Answers
  • Posted on Apr 13, 2009
 Kenneth
Expert
Level 2:
New Friend:
Answers
50
Questions
0
Helped
50155
Points
127
Fuel problem, the float in the carborator is stuck, if you tap on the carborator bowl it will probably get freed up.if not take the bowl off and spray the insides with carb. cleaner.
Jeremiah Jackson
Level 1:
  • Contributor 2 Answers
  • Posted on Jul 22, 2021
Jeremiah Jackson
Contributor
Level 1:
Answers
Questions
0
Helped
9776
Points
7
Update your firmware
1helpful
3answers
Generac Guardian Standby Generator 04760 15KW LP won't stay running
Turns out it was the Manual-off-Auto switch that was bad. My DVM showed a voltage drop across the switch. The controller wasn't getting enough power.
One good thing about it was it forced me to really study the schematics to understand how everything worked. I'm now in the process of designing my own esp32 based controller, with wifi connectivity, to replace the stock control board.
Generac repair
We have a whole Help Center and Engineers dedicated to helping people fix their Portable Generators. In addition to this we have a "Parts Search Service" if the part is not listed on our site. Check us out on our site. https://www.generatorguru.com/
Parts Spares for Generators and Small Engine Machinery
2answers
What kind of oil do you use
Judy, Generac portable generator oil recommendations. Above 40°F, use SAE 30. Below 40°F and down to 10°F, use 10W-30. Below 10°F, use synthetic 5W-30. Oil should be changed after the first 8 hours of operation and every 200 hours of run time thereafter.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.generac.com/service-support/faqs/portable-generator-faqs
http://www.generac.com/service-support/faqs/home-backup-faqs
Best oil for Generac generator Lawn Mower and Small Engine Bob Is The Oil...
Generac Generator Oil Change
Generator hard to start and sputters like its missing
About 15,000 results (0.73 seconds) Search Results
    2 - Generac : Questions, Answers, How To, FAQs, Tips ...
    answers.generac.com/answers/1506-en_us/searchquestions.htm?...
    Can I run an 8kw standby generator on a 100 lb propane tank? 2 answers ... What am I getting for the extra cost of the Guardian unit? ... The engine starts hard and runs rough. 1. Air ... On auto start, unit sputters and I smell gas. ... Does the gas and electrical feed into the unit from the back as previous air cooled units?
    2 - Generac Questions and Answers
    answers.generac.com/answers/1506.../generac.../questions.htm?...
    On auto start, unit sputters and I smell gas. .... The 20kW automatic standby generator has the option to delay start up during an ... This is for a guardian 20kw. ....has been designed to make the battery installation and removal so difficult? ... The air cooled generators are designed to allow for the smallest footprint while still ...
    3 - Generac Questions and Answers
    Generac's Guardian Series 17kw automatic standby generator does not come with a.... The automatic response features of our air-cooled units initiates the unit's startup,.... This week I tried the same and it tries to start but just sputters and fails until .... A C delayed start still chocks 17kw generator would a hard start kit help?
    On auto start, unit sputters and I smell gas. On manual start ...
1helpful
2answers
Error code - 2400...stopped-alarm- fuse problem, fuses checks good
I has this problem after performing Schedule A maintenance. Called Generac. They advise this a trip caused by removing the fuse before work to prevent engine start up, The fix is to turn unit in off position and then press ENTER key.
11helpful
8answers
Generac 43903 standby Generator overspeed indicator on starting
I have a generator that did the same thing. It would start and then stop within a few seconds. The more expensive generators have an oil level safety switch to prevent the engine from burning up. There is usually a wire connecting to the switch on the outside of the engine near the oil fill hole. Remove this wire and try to start the generator. If it runs without a problem then it is the switch. You need to remove the switch and take it apart carefully and clean it. There is a small float inside the assembly. When the oil runs low the float allows the switch to short to ground which kills the spark to the spark plug. Hope that helps.
Bob Janelli
I’m happy to help further over the phone at https://www.6ya.com/expert/bob_62dfa2f81bb55288
1helpful
1helpful
Generator Starts But wont stay running after a few mins.
check the oil level most products like this have a safety valve.
2helpful
2answers
It sounds like you are not producing any voltage. When you start your generator have a volt meter on the generator breaker to see if there is voltage present when the genset is running. Also, check you oil pressure switch, which is near the oil filter.
Top Generac Measuring Tools & Sensors Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you a Generac Measuring Tool and Sensor Expert? Answer questions, earn points and help others
