KitchenAid KCMS145J Microwave Oven Logo
Posted on Apr 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Doesn't heat the food
Microwave comes on and looks like it's working okay, but nothing gets hot and it is louder then usual when running.
Anonymous
Level 2:
Scholar:
  • Expert 192 Answers
  • Posted on Apr 11, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
192
Questions
0
Helped
86635
Points
437
The part you need is sometimes call a megatron, they may call it something now, but its the power that radiates through the unit. I think this may be the culprit Sorry but this is not a cheep fix. you may want to do a cost comparison . This happened to me only after the warrentee had expired . good luck with it. DFD
1helpful
Why Does My Sharp Microwave Turntable Get Hot?
I hope you didn't run the microwave with nothing in the cavity, if you did, it will damage the magnetron.
The turntable dishes do get hot depending on the quality of the glass used to make it. Heat is caused by impurities in the glass.
If you run it with no food in the oven, the glass will try to absorb the energy with atastrophic results usually.
All of a sudden the food does not get hot. The turntable does and everything looks to be working properly, but the food does not get hot.
call Chas&Son,s appliance repair at 570-379-0993 and they will come out the same day no less okay
Seems to cook okay, but its getting louder. What can I do?
If the sound is coming from the magnetron "heats food" it indicates failure within a short period of time. The only thing you can do is call an appliance repairman to check the oven out and verify the problem and cost.
My microwave is not heating up food. Everything else still works, but it is louder than usual. Lights, timer, fan, etc all work, the food is just not getting hot. It is about 4 years old.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
1helpful
Boiling waer under micro wave lots of steam into micro wave, turn on micro wave ,pop noise like glass miro wave comes on louder hum than normal no heat
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
HI. I have a Whirlpool Microwave (MH6141XKB). It will not reheat the food and makes a louder "humming" sound than normal. Other than that, everything works fine. Please advise. Brent
Brent
The magnatron in your oven has gone out and will need replaced!( This is the device that heats up your food) If everything is working and your food is not getting hot 99.9 percent of the time its the Magnatron or its fuse! The loud humming is also a big clue the MAGNATRON has gone bad!
Please rate this response and help us keep this area free!
Thank You!
GE Spacemaker Microwave, Model J VM1650AB5 Not heating food
If you sure that lauder sound comes from turntable motor than it needs to be replace.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
