I have power to the IFT drive, but no display on the user panels. How do I determine if the problem is with the IFT drive or display panels?
SOURCE: ???maximum user weight for Precor 9.45i
Normally most home treadmills are 250-300lb user capacity.
Call Precor with your model # and S/N and they can tell you exactly.
SOURCE: The belt on my Precor
Error 22 means the drive motor is diconnected. you will hear the fan and other parts make noise but check the red and black anderson connection between the main circuit board and motor.
SOURCE: Where can I find a Precor 9.21 treadmill motor cover?
Do you know which version of the Precor 9.21 you have? There are a few different versions you can view here. Click on your version to view the parts list and look for "Cover, Motor" or "Motor Cover".
For instance, if you have the 9.21 (AYYZ), the proper motor cover is this part #5019749
However, this part #5005569 is listed as the proper motor cover for the 9.21 (F5), 9.21i (2X), 9.21s (F6), 9.21si (2Y), and a couple others. Make sure you have matched up your exact model number with the motor cover you need so do you not order the wrong part.
SOURCE: Parts for a PreCor 9.1 treadmill
go www. precor.com or www. fitnessrepairparts.com or www. treadmillspartszone.com
God bless your
SOURCE: SPEED ERROR ON PRECOR 927 TREADMILL
I had the speed error on my precor 9.23. When I opened it up I found that there are two little round magnets on the belt pulley with a sensor mounted nearby. This must be how the computer know the speed of the treadmill. I noticed that there were several little metal shavings stuck to the magnets. Not sure where they came from, hopefully not another problem. However, I removed the metal shavings from the magnets and everything worked fine again. If anyone else has the speed error it might be worth a look to see if its the same problem.
