Precor EFX 5.21s Elliptical Cross-Trainer Logo
A
Anonymous Posted on Aug 27, 2013
Getting an err40 code - Precor EFX 5.21s Elliptical Cross-Trainer
Sportsmith LLC
Level 3:
  • Precor Master 920 Answers
  • Posted on Jul 29, 2014
Sportsmith LLC
Precor Master
Level 3:
Answers
920
Questions
0
Helped
514831
Points
111994
Precor Error 40, No Lift Motion Detected Probable Cause 1. Blown lift fuse in lower PCA.
2. Lift motor is physically jammed and not able to move.
3. Bad lower PCA.
4. Bad lift capacitor.
5. Bad lift motor winding.
6. Bad interconnect cable between upper and lower PCA.
7. Bad upper PCA.
Corrective Action
  1. Check the lift fuse from the lower PCA. Using an ohmmeter, the fuse should measure 1 ohm or less. If the reading is significantly high, replace the fuse. If the fuse is open, refer to steps 3 and 4 before continuing.
  2. Disconnect the lift motor from the ramp (elliptical) or lift platform (treadmill). If the lift nut or lift tube is jammed against the motor housing, turn the lift tube or lift nut away from the motor housing. If the lift was jammed, refer to step 3 before continuing. Calibrate the lift motor per the proper procedure for the unit being serviced and reattach the lift motor to the ramp (elliptical) or lift platform (treadmill). NOTICE: You must find and repair the cause for the jammed lift. Only re-calibrating the lift motor will not solve the problem.
  3. One of two modes can cause the lower PCA to fail. The lift switch could fail in an operated condition. If this happens the lift will move (either up or down) as soon as the unit powers up. The usual result is that the lift will be physically jammed as explained above, and probably also being cause for the lift fuse to blow. The lift switch could also fail in an open condition. If this happened, the lift would not operate in one direction. If either of these conditions occur the lower PCA needs replaced.
  4. Most units have the lift capacitor mounted inside the lift motor, and others use external lift capacitors. This information applies to units with the external lift capacitors. If the lift capacitor is shorted the lift fuse blows. Check the capacitor for a short using an ohm meter. Disconnect the capacitor from the lift motor and test. A good capacitor reads in the millions of ohms. Replace the capacitor if the reading is significantly low. Capacitor can also fail in the open condition which would result with the lift motor trying to run but not having normal power. Test the capacitor by measuring AC voltage across it. A good capacitor will read AC peak voltage while an open capacitor reads AC RMS voltage.
  5. When a lift motor winding is bad the lift will not operate in one or both directions depending upon the exact fault in the motor. Check the lift motor winding with an ohm meter. AC lift motors have a split winding (3 wires) and DC lift motors will have a single winding. Both windings must be checked on an AC lift motor. Normal winding readings could vary anywhere between 1 and 60 ohms, depending on the lift motor being tested. See the proper service manual for the motor being tested.
  6. Test unit with a known good interconnect cable. Replace the interconnect cable if necessary.
  7. Test unit with a known good upper PCA. Replace the lower PCA if necessary.
Precor Error Code 40
Precor repair manuals
Repair manual to this TV is in my system, but it can't be send to you, as it is PDF.
21helpful
13answers
How to get my ninja saga candy code??
  • 03C20DB76A5B6D588478918574EB963C70
Nov 07, 2012 • Ninja Saga
1helpful
2answers
How to get code
What is your mobile and model ?
Also what type of code does your mobile needs ? Is security code or network unlock code ?
If security code means get it from the mobile service provider otherwise want network unlock code get it here Unlock-free.com , it gives you a best instructions for getting the code for your mobile from the network lock........
Nov 14, 2011 • Cell Phones
Electrolux ewf1087 Err40
Hello, Marlene
I am trying to help you out here. Maybe this will help some? I am know on Fixya as the cleanup expert pro. Which means I spend my own personal time to seek out customers that maybe have not had there problem yet solved by the other fantastic great experts. I do this on my own for free. Think of me as a Specialized Trouble Shooter.
I have found out that it appears that lots of customers appreciate my efforts and help. So, I thought I would take some of my own personal time
to see if I can help you. Even though this Informational site may not have your exact model or brand, But this site will help you a lot. Here is the site link about everything you want to know about washing machines and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help, I would appreciate it. Like I said I just try to help, If anything this is good information for future problems. If you felt that my free help was a waist of time for you, I'm sorry. I do not get paid to help people on the site, I do it cause I like to help and maybe make a smile on someones face.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
http://beta.fixya.com/users/mc1bean
Thanks Mike
4helpful
5answers
Hi i want to unlock and get the MEP code for my blackberry bold 9700 here is my IMEI #: 359564.03.121762.5 thank you
No one can give you free unlock code. because each blackberry have different unlock code. As far as i know unlocking by codes is the simple and safe way.You will need the unique MEP Code for your Blackberry and to get it you can use a website with service for Blackberry unlocking .so you can use a website to Unlock your Blackberry Bold 9700 online instantly - OR local mobile shop .they are mostly using cables to unlock it and the price is higher then on unlocking websites but the result is the same: SIM free Blackberry.
3helpful
What is my code?
It asks for PUK Code or PIN code means get from service provider ,asks for Security code means you can get the code from service provider,If asks for Network Unlock code means you can get the Unlock code from here
Theunlockspot and unlock it,check code for Mobile Brand ,Model,network and Country it locked now?also you can reset the Phone from security code or password lock code using the master reset code,You can get the Master reset code for Nokia DCT Phones and Alcatel Old Model Phones there itself.
Aug 15, 2011 • Cell Phones
I am getting Error code 0x80043ac9
What Code Error,Security Code Error getting while entering code,or else getting code error while entering the Network Unlock code,?
You can get the Network Unlock code correctly at here
http://www.mobileunlocksolutions.com/blackberry-bold-9000/rs1wp9/ as well as security Unlock code at there ...
6helpful
11answers
Blackberry codes
You can get the MEP code from the mobile carrier or vendor ,
who provide the blackberry device,
this is service is not a free service in market or internet,
3helpful
Looking 4 samsung j750 unlock codes
hi,
you are in need of of unlock codes right
the fact his you cannot get it forfree..........................
you have to spend some money to get unlock codes youcan get your code according to your specified imei................
you can get it within 1-2hrs
and activate your code quickly....... to get codeyou refer this site
here is the link
Click Here ...................i hopethis site provide you codes quickly and easily
All The Best
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
