Destroyit 5009 Shredder No power to the oil pump. Otherwise machine is operational.
Investigate the operation purpose of the Oil Pump. Did you measure the voltage across the terminal or observe that the pump was not operational. It must have an auxiliary function that is not related to main operations. Investigate the purpose of the Oil Pump and deduce what would make it operate then check that switch if their is no voltage measured across the pumps terminal when it should be operating. This deductions may help lead to the problem and a solution.
SOURCE: we have a destroyit 2602 cross cut shredder, when
The paper sensing switch lever has bent or broken or the switch is faulty. Check between the wheels about in the middle of the shredder to see if you see if the little plastic finger. If the finger is visible and can be moved, the switch is faulty. REMEMBER TO UNPLUG IT BEFORE DOING ANY INVESTIGATION.
SOURCE: i need a parts manual for destroyit 2502cc
That shredder is obsolete, but you can probably get parts from shredderparts.com
