Freezers Logo
Anonymous Posted on Apr 11, 2009
Buzzing noise -Kyoto KU 9577 Freezer
The freezer is making a buzzing noise and starting to defrost....
I don't have a manual for it! :(
There is a red light on (on the front of the appliance-it has a triangle above it)-is this a warning light? and the fast freeze yellow light comes on when it is switched to fast freeze.
Turning it off and on gets rid of the buzzing but not for long.
Any help appreciated.
James
  • 3 more comments
  • Anonymous Apr 11, 2009
    Thanks-where do I find the relay and what should it look like?
    James
    hI-WHAT DOES THE R4ELAY LOK LIKE?
    Right. Got it off. It does rattle but hardly like a bag of gravel-more like a switch being opened and closed. It's made by Klixon and has a variety of numbers on it.
    The buzzing seems to be coming more from the top of the freezer (it's a frost free model) and the compressor gets hot when it's on and there are various dripping sounds inside the two tubes running down the back....
    Compressor/ relay/ something else?
    sounds like a good idea.
    thanks
    Apparently the part I need is the same as on the Servis M767. It's on order.
    I also decided to smell the relay. Perverse, perhaps, but smell that burn! Nearly a house fire there!
    And thanks again.
Anonymous
Level 2:
Scholar:
  • Expert 102 Answers
  • Posted on Apr 11, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
102
Questions
0
Helped
59817
Points
275
You may have a bad compressor or a bad compressor relay. The buzzing noise sounds like the compressor trying to start but can't. Unplug the unit and pull the relay off the compressor. If it rattles like gravel in side it replace the relay. If it doesn't then you may need to call a repairman to check the compressor. Hope this helps.
  • 2 more comments
    there are several different versions of a compressor relay. It is located on the side of the compressor and all the wires hook to it. You may have to pop off the compressor cap to get to the relay. Many times it is a 2 piece relay. Brown relay on top and white and black overload on bottom with one wire hooked to it. The overload almost never goes bad.
    Replace that relay. Bad relay makes the compressor very hot. You can actually use part #8201786. It is a whirlpool # but it will work.
    you are welcome. Thanks for using fixya.com and don't forget to rate me. Thank you DM
    Hee hee!! Yes. I have seen 1 that almost caught on fire. More than welcome. Glad to help.
1helpful
Started making a loud buzzing noise. Have tried unplugging it and turning it off and on.
Good Morning Denise, thank you for your inquiry!
From the information you have provided your Frigidaire freezer is making a buzzing noise and it will not stop. You may need to perform a reset on your freezer and you can do that by disconnecting the power cord for at least ten minutes. If the buzzing continues I would be happy to research your freezer further, in order to do so I would need your model number. You can locate the serial tag (which lists your model number) on the inside wall. Once I have that information I would be happy to help you further. -Matt
1helpful
Hello my freezer is not cooling properly and the defrost timer is . making a loud buzzing noise. Please help
Your freezer compartment will freeze up and not cool properly if the defrost timer does not allow the unit to go into its self defrosting mode to get rid of the ice that serves as an insulator.
Replace the timer.
1helpful
My amana upright freezer was working fine, but transported it to another location when I plugged it back in, it started to make a buzzing noise. How do I turn this off or fix it?
Hello....First...when you transported the freezer...you must sure the unit stays in the vertical position and not laying on it's side...back..or front....If the freezer is making buzzing noises...adjust the thermostat setting down until the buzzing stops...and increase the setting gradually until the desired temp is reached...it could take 24 hours for it to stablize...I hope this was helpful.....PEACE.......
After loading freezer a loud buzzing sound started
Is it coming from inside the freezer or outside? If outside either the auto defrost timer is a problem. If the noise comes from the compressor, almost certainly the starter relay inside the electrical cover needs to be replaced. It can be purchased at most refrigeration outlets. If coming from inside, you need to defrost the freezer properly for 12 hours then restart. The noise should go away then.
1helpful
1helpful
Buzzing in a full freezer with icemaker model no. 253.44133802
try cleaning vents/drain holes in whole unit this should allow more air to flow.also when did you last manually defrost whole unit.....
My freezer stopped freezing and is making a loud buzzing noise with the red light on at the bottom. Cant sleep HELP
the loud buzzing is the freezer high temp alarm. dont know why its warm though.
make sure you don't store anything on top of or on the sides of the unit as the condenser of most freezers are buried in the walls of the unit and it will over heat the compressor. if unit is in a hot garage this will compound the problem.
1helpful
Brand new unit, compressor noise.
Since I could get no one to tell me about new freezer compressor making buzzing noise while on, I had the store come a pick it up and give me my money back.
1helpful
Loud buzzing noise
IF YOUR FREEZER HAS A TEMP ALARM, USUALLY LOCATED IN FRONT,BOTTOM, RIGHT CORNER, THE TEMP IS PROBABLY ABOVE THE SAFE TEMP FOR FREEZERS, (10 DEGREES) AND SO THE ALARM WILL SOUND.
THERE SHOULD BE A SWITCH IN FRONT TO SHUT OFF THE ALARM UNTIL THE TEMP GETS BACK DOWN TO ZERO. THEN YOU CAN TURN THE ALARM BACK ON.
IF YOU PLUG IN THE FREEZER AND TURN IT ON, IT SHOULD BE BACK DOWN TO NORMAL TEMP (IF IT IS EMPTY) IN ABOUT 24 HOURS. IF IT ISN'T, YOU HAVE OTHER PROBLEMS. CHECK TO BE SURE THE COMPRESSOR IS RUNNING.
Top Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Freezer Expert? Answer questions, earn points and help others
