"Kaidaer should be powered ON to function, except when only charging the built-in battery, in which case it should be OFF with the Data/Charging Cable connected to a USB charging source"
I believe I was told that I could charge the Kaidaer Mini speaker MN02 by simply plugging in the attached lead to the computer. But while this allows the speaker to function it does not charge the battery inside.So did I hear wrong? I have since been informed that I need the power adaptor that plugs into a wall socket to charge it, as a computer is not strong enough to charge it. But I'm still not sure...how do I know that the battery may just be dead? Can anyone advise on how they charge theirs? Thank you.
you must try if you have some instr. manual try to download from. www.manualsonline.com However you must test the button with DVOM tester for open or continuity and repair or replace. Maybe some loose wires or cold solder. God bless you
Release Round plastic from bottom just pull it out and then remove the bottom cover using a knife or small screwdriver, the cover in only attached with glue.
