Heavy Machinery Logo
Posted on Apr 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Chipper is jammed. need to know how to unjam
Attempted to take face off but unable even after it appears that all the nuts are off
Derrick Schultz
Level 3:
Top Expert:
  • Yard Machines Master 11,405 Answers
  • Posted on Jan 23, 2019
Derrick Schultz
Level 3:
Top Expert:
Answers
11405
Questions
0
Helped
2330369
Points
23972
I have a chipper too, and it started giving lot of problems 4 yrs ago, so I got this free Pdf manual from reliable-store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of the 20 times I fixed the chipper in these 4 years
2 Related Answers
Yuk-Wa Chan
  • 133 Answers
  • Posted on May 29, 2009
SOURCE: Unjam a MCFC printer
back cover is just on the back of your printer.
Anonymous
  • 2296 Answers
  • Posted on Dec 02, 2010
SOURCE: Paper jams too often and for no apparent reason.
To clear the paper jams always follow the instructions from the manufacturer, here is the support page from Brother website.
Also, sometimes when I get paper torn inside, I use a pair of long-nose pliers to remove it, but be careful not to damage any parts inside the printer.
If the printer is jamming constantly then that means you have a hardware issue in there. Look carefully where is usually jamming and see if you have a clip that stops the paper or a roller that's not pulling the paper and try to fix it or replace the faulty part.
Shredder jammed and will not back up - how do I unjam it?
Carlo, unplug shredder, patiently use pick, scissors etc to remove stuck paper. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Unjam Paper Shredder
How To Fix Paper Shredder Jam Video
How To Clear Jammed Paper Shredder ABC Office
Best Way to Clear Out Jammed Shredder Ask Ozone
Staples jammed.How can I unjam and open it?
Hi Alan:
You don't specify what make it is, or if it is powered.
If air, disconnect from supply, remove any staples from magazine, and attempt to discharge.
There will be allen head screws holding the firing mechanism assembly together. Always treat it as if it could discharge.
Carefully loosen the screws and try to remove the jammed staples with a small screwdriver. You may need to actually dis-assemble it to get it unjammed.
Clean parts, oil, and re-assemble.
Should be fine.
HOW DO I UNJAM SB 99C SHEDDER
Try spraying some WD40 into the cutting blades then turn it on to forward it may unjam itself.
How to adjust clutch cable
set pedal to 1/2 play.
or are you asking how at the hands level?
you unjam the jam nut, and turn the adjuster, set play and set jam back.
its in the FSM
or at alldata.com
the FSM shows you and the zero knowledge level, that is
it shows you the nut and says, turn this , then....
in school you learn all this and never needs being said.
called BASICS.
are you asking basics. ? please say so... (inlcudes safety !!!!!)
ever adjust bicycle brakes. (same deal , a a cable and same deal the mandatory play)
I have a hitachi NR 83A2 framing nailer with a jammed firing pin. How do I unjam it? I have the exploded diagram. thx. andrea
by jammed I take it you mean a nail has jammed the driver? If that is the case there is really no easy to unjam it. But unplug the air hose and turn tool upside down and wearing safety glasses and gloves you can try and take a punch smaller than the nose piece and try hitting the driver to unjam nail. If it is another problem please let me know and I will try and help more.. Sometimes we used to have to remove the nose and heat and it goes on but hopefully it is not that bad
Jammed Cartridge
You need to clean the encoder strip, the clear strip behind the carriage. You can wipe it carefully with a damp Qtip because with too much ink on it the carriage thinks it's not moving.
4helpful
2answers
Starting craftsman 6.5 hp 4 in 1 leaf vacuum
Check to see that bag is attached correctly as it has a kill switch.
Printer keeps on jamming
could be improper bond weight or thickness of paper, too much paper in the tray, or the wheels on the feed rail inside is broken or needs to be cleaned
Paper jam, so small, can't even see paper
first off, unless you know that the paper is there, it's a possibility your machine is just saying or acting as if there is a jam when actually there is something giving a false reading or a failed part rendering it unable to print. Otherwise, if you happen to know where there paper is jammed at, attempt forcing a heavier stock paper through. say the jam is between two rollers attempt pushing a cardstock or index card thickness of stock through the rollers to attempt pushing the paper backward which might either remove the jam and make it removeable elsewhere, or make it so the machine can try to feed the paper through again this time allowing you to reach it.
Top Yard Machines Heavy Machinery Experts
Dmitry Isayev
Dmitry Isayev
ADMIN Andrew
ADMIN Andrew
Are you a Yard Machines Heavy Machinery Expert? Answer questions, earn points and help others
