It also yesterday would just give off a loud beeping and a F-1 ERR in the display. Now I cannot unlock the oven it will not do anything but beep if I touch the control touch panel.However the stove top works fine, it has dials.
The F1 code means the ERC or the touchpad is bad.
F1 fault code generally implies that the electronic oven control
has detected an internal malfunction. Most likely the cause is a
shorted keypad which would require a new electronic control board. The
electronic control board internal checksum may have been corrupted
which also would require a new electronic control board. The control
also may have sensed a potential runaway oven condition. The control
may have a shorted relay, RTD sensor probe may have gone bad. The RTD
is the oven temperature sensor probe which needs to be ohmed and the
resistance should be 500 ohms or more at room temperature. If the
resistance is less than 500 ohms, replace the oven sensor. Normally a
technician is needed to make this check.
I recommend calling a service technician to diagnose and repair your oven.
Hi
Error
code F0 means that an error with the keypad has occurred. Usually it happens
due to loose ribbon cable on the keypad or the electronic control assembly
itself going bad. To resolve this issue first, disconnect the power to unit and
then gain access to the back of the clock assembly (Electronic Range
Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would
be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable
is not broken and nothing is shorted on the keypad. After this is done insert
the cable back and then plug the unit back to check. If the error is still
there then the electronic control board should be replaced. Hope
this helps...please post back for further assistance.
Daniel
