Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher Logo
Posted on Sep 09, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Installation we have two loose white acordian type hoses, one attached to the side of the unit and the other comes from underneath. Do we attach both hoses to the drainage under the sink, and if not where does the hose go that does not go to the drainage under the sink?
  • tyymer Oct 01, 2007
    Ok we have it connected but the dishwasher will not drain now. Now what do we do?
Anonymous
Level 2:
Sniper:
  • Expert 68 Answers
  • Posted on Aug 19, 2008
Anonymous
Expert
Level 2:
Sniper:
Answers
68
Questions
0
Helped
92276
Points
173
It sounds like you have connected your dishwasher to a garbage disposal.
  1. The 2 hoses provided with your dishwasher connect together.
  2. You run the drain hose through a hole in the bottom/back of your cabinet, then up to the top of the cabinet, then connect it to the drain on the garbage disposal. (The reason that you run your drain up to the top of the cabinet is: This is called an air gap, and helps keep a little water in the drain line, which will prevent sewer gases from entering your dishwasher.)
  3. Be sure to knock the plug out of the drain of the garbage disposal. A garbage disposal is designed to work with or without a dishwasher. The plug is in the center of the drain. The best way to knock this plug out is to pull the garbage disposal, and with a flat screwdriver, knock the plug out.
  4. Then remove the plug from the disposal. Reinstall the disposal.
  5. Install the drain hose. The drain hose will connect right up to the disposal using the clamp provided with the dishwasher.
This should help you. If not please attach more info.
Please rate this solution
A
Anonymous
We have a garbage disposal and the hose underneath the dishwasher is connected to it, the hose on the side we put underneath the dishwasher to go into the drainage pan that is there
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Sep 26, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2034
Points
The loose hose under the dishwasher connects to the hose on the side of the dishwasher. the hose on the side is looped around is acting as a anti-siphon to control the dishwasher from draining as it's filling.there should have been a clamp with the dishwasher to connect the hoses.
  • Anonymous Oct 02, 2007
    do you have a air gap on top of the sink?do you have a garbage disposal?let me know.
I have a hose on the leftside of compartment, in front of fire wall, 6" piece that comes off of tee.97 bravada
Did not get the complete message, but I am thinking that the hose is loose, not attached to anything. There should be another tee fitting to hook it too, or look for a vacuum reservoir shaped like a ball. It may have come loose from there. The ball is usually attached to the left side of the hood.
2answers
There is coolant leaking on the passenger side underneath of the car and rear of engine. It doesn't seem to be the lower hose and both the rad and thermostat are new and appear to be dry. I suspect the...
agree, heater core. see procedure below
REMOVAL & INSTALLATION
  1. Disconnect the negative battery cable and disable the SRS system (if equipped.)
WARNING All SRS wire harnesses are covered with a yellow insulation. Read the SRS precautions found in this section and install the short connectors as described.
  1. Properly drain the cooling system.
  2. Disconnect and plug the heater hoses at the firewall.
  3. Disconnect the heater valve control cable.
  4. Remove the heater unit attaching nut on the firewall.
  5. Remove the dashboard as follows:
    1. Remove the center panel.
    2. Disconnect the wire connectors at the fuse box.
    3. Disconnect the sunroof switch connector, if equipped.
    4. Disconnect the ground cable at the right of the steering column and the power mirror switch wire connector.
    5. Remove the side air vent knob and face plate.
    6. Remove the screws attaching the air vent control lever.
    7. Remove the center panel, radio and heater control head.
    8. Remove the gauge upper panel (4-door) or instrument panel (3-door).
    9. Disconnect the speedometer cable.
    10. Remove the center upper lid.
    11. Remove the side defroster garnishes on both ends of the dash.
    12. Lower the steering column.
    13. Remove the dashboard mounting bolts.
    14. Lift and remove the dashboard assembly.
  6. Remove the heater duct.
Fig. Fig. 1: Removing the heater duct assembly
  1. Remove the steering column bracket and duct assembly.
  2. Remove the heater assembly mounting bolts.
  3. Remove the heater assembly and remove the heater core.
Fig. Fig. 2: Removing the heater case assembly
Fig. Fig. 3: Removing the heater core from the heater case
To install:
  1. Install the heater core into the heater unit.
  2. Install the heater assembly and the attaching bolts.
  3. Install the heater duct and steering column bracket.
  4. Install the dashboard assembly. Tighten the mounting bolts until just snug.
  5. Raise and attach the steering column.
  6. Install the center upper panel.
  7. Connect the speedometer cable and install the instrument gauge assembly.
  8. Install the control head, radio and center panel.
  9. Install the side vent and face plate.
  10. Connect the ground cable at the right of the steering column and the power mirror switch wire connector.
  11. Connect the sunroof switch connector, if equipped.
  12. Connect wire connectors at fuse panel.
  13. Install the heater unit attaching nut on the firewall.
  14. Connect the heater valve control cable.
  15. Connect the heater hoses at the firewall.
  16. Connect the negative battery cable.
  17. Fill, bleed and leak check the cooling system.
1helpful
I replaced a clogged drain hose attached to my Aprilaire 600 humidifier. I then discovered no water was being supplied to the humidifier. The problem appeared to be a dangling solenoid wire that I had...
No, you need to attach one of the solenoid wires to the red wire and one to the white wire.
So, undo the wire nut with the three wire and hook one of the red or white wirtes to the wire nut with only one wire. Then you sould have a black wire and one of the other red or white wires under each wire nut.
Problem amy be that you now have burned out the transformer that runs your Humidifier. By hooking the red and white wires together you may have shorted that out and killed it.
If you humidifier does not work after hooking it back uo right then you will need to change the transformer.
Heatman101
Washer runs water all over the floor, but not every load, it's not coming back out of the drain
Most likely the problem lies with the pump. Its a plastic box attached to the motor beneath the machine. Most likely there is a puncture in it somewhere or possibly a loose hose underneath. Check out the hoses and the pump for issues. The pump is generally a gray plastic with two black hoses coming out the left side.
47helpful
4answers
F35 & SuD error codes on Kenmore Elite Washer
F35 has to do with the pressure switch which is located under the top panel on the back right. It will have a little black hose hooked to it. This happens when SUDS or detergent somehow gets up into it and usually locks unit out. Only solution is to replace pressure switch. You can find the tech sheet behind the bottom front panel usually tape to the back side of that panel or taped to the bottom right side inside unit. Hope this helps
Hot air blowing out passenger side ac vents only
Verrrrry carefully. You can start by removing the glove box to look underneath the panel and see what is happening. It is unlikely that something came loose, instead it is likely that you have a leaky or unhooked vacuum hose that operates the dampers to make the air come out the top or bottom vents. The hoses are about a 1/4 in. diameter and fit on nipples attached to the dampers.
Good luck.
1helpful
Connecting hoses on Kirby G4
The hose attaches in place of the beater-bar head unit. To remove the head unit, lift the headlight assembly, then turn the square gray Kirby emblem counter-clockwise 3/4 of the way around until the red triangle on the square portion aligns with the red triangle on the base unit (this disengages the belt). Then flip the silver metal fastener that was underneath the headlight to release the head unit and remove the head unit. To attach the hose, simply line it up so that the safety button is engaged by the hose assembly and then use the metal fastener under the headlight to secure the hose to the base unit.
4helpful
Gaggia titanium leaking water underneath
i had this same problem. the solution is simple if you are a little bit handy.
there is a bad valve inside. i called Whole Latte Love where i bought the machine and ordered a Steam Valve complete - Compact Frame
its part number GA-%0345.R and two O-Rings
the valve that comes with the machine is plastic and the new one is a brushed metal casing. my guess it will last for 10 years!
two screws on the back and the machine is open
near the front, by the steam wand, with a hose attached coming from the heater, is the valve, attached to the knob on the side
two more screws and the valve wrapped in a plastic housing comes out.
open the plastic housing, remove the insulated hose to the steam wand and the water/steam plastic hose that comes in. replace the valve, hook up the two hoses, but back in housing and you're done. attach back to knob on the outside, put back together and in 30 minutes, the Titanium is like new. no leaks.
it sounds daunting but is pretty easy and beats sending the machine back for repair. i can't go a morning let alone a month without coffee from my Gaggia. once repaired, the coffee is hotter too.
2answers
Hoses to and from pump
I have a Bissell Model 1699 when I removed the pump to this unit to go buy a replacement I wrote discriptions of where the disconnected hoses went. Apparently my descriptions were poor. Now after switching the hoses all around I am not sure where they go. I cant get the thing the thing to go backt together because apparentely the hoses arent routed properly How can I find out where they are supposed to be connected and how they are routed.
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
