HELLO
I FACED PROBLEM WITH UPPER PRINTER WHICH IS SAY JAM INSIDE REAR BIN.THE A5 PAPER ALWAYS JAM OUT OF FUSER & ALWAYS FOLDED FROM TRAY1.
ITS JAMMING FROM FIRST PAGE.
ASSISET ME PLEASE.
As i can understand whenever you try to print with rear door closed printed page should come on top from top output roller however paper gets jammed.
Solution:
Try to print a page using rear door open and it should come out from the rear drop down tray it printed page comes out successfully with rear flap open than paper gets jammed at top due to faulty top output roller.
However if the paper gets jammed at fuser with rear door closed than it is issue with fuser in that case you need to get fuser replaced at the same time replace 20 tooth gear next to fuser.
Thanks and Regards
Neeraj Sharma
SOURCE: I just replaced the Fuser
First, make sure that both wire connectors on the right side of the fuser are seated correctly.
Then, see if there is paper sticking a little way out of the fuser. If so, chances are the exit sensor in the fuser is not functioning correctly.
You can put the old fuser back in and verify this if no error codes come up.
SOURCE: I just replaced the Fuser as well as a new Toner
The problem is in the fuser exit sensor wich is behind the rear cover of the printer.Take of the rear cover and look if the lever of the paper sensor is in the wright place(the end of the lever should be between the two diods of the sensor).If the lever is in wrong position the printer will think that there is paper jam. If you need any other help please write to me. Please vote if this was helpfull.
Testimonial: "Thanks, great suggestion...where's the paper sensor...?"
SOURCE: Can't Install HP LJ P3005 to XP
Try downloading and installing the XP driver from
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1846089&prodTypeId=18972&prodSeriesId=1846088&swLang=8&taskId=135&swEnvOID=228
SOURCE: I'm looking for HP LJ P3005 formattar board
Take the right cover off(it slides back)
The metal piece you now see is the formatter cover.
YOU HAVE UNPLUGGED THE PRINTER. Yes!!!
Open the cover, lift it off the hinges.
Disconnect three cables. I believe that two of them are ribbon cables, please be carefull. Remove the six screws.Pull the left side of the formatter out slightly, and then slide it towards the front of the machine.
Reverse the process to install the replacement. Center the ribbon cables on the connector and gently push them in. Don't force them.
SOURCE: In HP LJ 3055 MFP
This seems to be fault in the transport of the paper in the rollers. So if you have used any adhesive sticker printing, it is possible that some glue has got clogged into the rollers. If not there can be some jammed paper in the rollers or the mechanism.
So start this work only if you are mechanically able with the right tools.
Remove the covers to get access to the mechanism . Remove the motor drive assembly , the fitting of the motor to the mechanism. Once this is removed the rollers can be turned manually so that you will be able to feed a paper to see the progress of the movement while studying if there is any obstruction or damage to the paper.
There is a in-detect sensor, usually an opto-coupler , make sure this is not clogged or dirty as this IR detection feeds the signal to the processor for starting the motor drive feed.
Reassemble but make sure the rollers are aligned to be in equal gap to feed the paper without a side pull. Now you must print and see if the fault has changed. If not repeat the above work to confirm the area of obstruction.
