I was trying to pick up loose paint I had stripped off the walls. My Hoover 5753-900 Windtunnel stopped working after about 2 minutes. I think the loose paint is stuck in the vacuum. I cleaned out the filters, but I think the problem is somewhere else. I need help
Take the bottom plate off where you would install a new belt. the impeller is clogged up. use a wire to poke out the clogs. you can use a shop vac to **** out the debris. check your belt for wear spots while your at it. you may need a new one . befor removing the belt. make sure you notice in what direction it is installed. If you put it on backwards you brush will turn in the wrong direction,not good. draw a picture if need be. Ok good luck DFD
