Cannot turn on TVour TV model is 60SBX78B, Hitachi project TV
Our TV model is 60SBX78B, Hitachi project TV.
it cannot turn on now. I unplug the power and plug again. then turn on TV, the power red light (indicator), it turns on but one second later it off right away. i tried many times, same result. thanks for your help.
Re: cannot turn on TVour TV model is 60SBX78B, Hitachi...
If your remotes are out of the room and you try to turn and it still wont come as it should ,then You have a problem with the power switch or the supply, your unit needs to go to the shop . Sorry. DFD
Hey there,
You'll have to contact the Hitachi local customer care and order a replacement.
It won't be that much of a cost, maybe around $20 or so.
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 13.0px Arial}
Thank you for using FixYa!
I hope that I helped you & that this post is helpful to you at most!
replace pico fuse E994 and capacitor C707. You have to disconect alot of wires and remove the screws holding the boards. you DON'T have to remove the large high voltage wires. You have to stand the board on it"s edge to unsolder the components from the back side of board. Good luck it worked fine for me. [email protected] gene
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off. Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address. Here are the symptoms...
You can get the parts from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix the following models (50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B).
hello. the loud pop you heard was .maybe a fuse.? u need to uplug .!!! the set !!!. and take off the back and see if fuse is bown.? ok let me know.!! ok
The green led or lights on the board indicate some of the power supplies are working. The key is do you see any come on and then go out. this would indicate which part of the power supply is failing. also there are fuses in the set that do not look like your standard glass fuse. WARNING television generate lethal voltages that will hurt you. extreme care should be used.
On this Hitachi model there is a common failure with some capacitors and fuses. Its a simple fix if you know which parts to use/avoid and how to do the repair. You can get complete instrucitons and parts for your model from www.TvRepairKits.com . Their kits include step by step photo instructions as well as the correct parts to fix this issue.
