I own the haier 7.3 cu ft freezer model hcmo73pa and added alot of fresh beef the temperature alarm went off and won't go off how long will it take and if you turn the white button on the bottom of the control area the other way it will qiut buzzing can you do that and the meat is still freezing correctly or not?
SOURCE: Haier 5.0 cu. ft. HCM-050 not freezing
I have the same freezer and recently it quit freezing. The thermostat is my problem. I checked the power outputs to turn on the compressor and it was not there until i tapped on the thermostat. I am currently trying to find another thermostat
SOURCE: freezer freezes but does ever stop running
thermostat is stuck on! set to medium setting and gently tap stat. does it turn off? it was stuck. does it still run? its still stuck. if you feel comfortable find stat and power in and out. disconnect - it has to turn off then. but 99 % of the time its the stat. they fail closed and run 24 -7 or fail open and temps get real hot and they never close and restart compressor . yours appears to have failed closed. sometimes you can firmly twist em max cold to min cold a few times and break the stuck contacts and they'll do ok for a while. try to reset at a little higher or warmer temp when done so its not making and breaking on the same old worn spot again. good luck.
SOURCE: my Haier 7cu. ft. deep freezer gets hot on the
It 's builded that way so there's not condensation around the door frame and on the walls.
