Question about NorStar M7324 Telephone
I have a Nortel Norstar phone and all the features seem to have stopped working. I can't access the voice mail or the get the general delivery mail box to turn on? Help!
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
Check to verify that the features are still programmed on the buttons. You can do this with Feature *0 and pressing the buttons. Try to manually do a feature button. Feature 86 will provide background music and Feature #86 will turn it off. Feature 85 will put your phone in DND and Feature #85 will restore it.
The other thing you might try is to unplug your phone and plug it in letting it set up several time to reset the port.
Also try swapping the phone with another extension to see if it is the port or the phone. Does the trouble move with the phone or stay in the same place. It is the phone if it moves with it or the port if it remains in the same place.
Posted on Feb 09, 2014
SOURCE:
When I press memory buttons on one particular telephone in our office they all dial reception. How do I fix this?
PDF]Telephone Features Programming Guide - Avaya Support
https://downloads.avaya.com/css/P8/documents/100142941 AvayaNORTEL NETWORKS is a trademark of Nortel Networks. ... All other trademarks and registered trademarks are the property of their ... One-line and two-line displays . ...Memory buttons . ... Call anomalies for telephones without line buttons . .... Select how you dial your calls . ... Receive a busy signal on an internal call .
Norstar How to program phone how to program voice mail ...
www.phonserv.com/1_PDF_user_guide_meridian_norstar_phone_syste...
Nortel Networks Meridian Norstar How to program voice mail phone feature codes ...Modular ICS KSU must be programmed with an M7310 or a M7324 telephone. ... Lift handset, press Voice Call key or press the Feature button, then press 66 2. .... At the LOG: prompt, enter your mailbox#(extension #. and your password all ...
[PDF]N QRTEL NORSTAR
Jan 18, 2016 | NorStar M7324 Telephone
Why would a NorStar StarTalk suddenly stop accepting voicemail calls?
"Q: My Norstar Startalk, Flashtalk, or voice mail says my mailbox is not accepting any more messages. I deleted all my messages, but callers still cannot leave a message. Why?
A: Check with your voice mail administrator. Chances are another Mailbox on the system used up all the message storage space. Usually it's the general delivery mailbox that hasn't been checked for messages on a regular basis."
Frequently Asked Questions
The following discussion suggests that voicemail can be inactivated, and cab be re-activated by logging in and pressing '4'
Startalk Flash Won answer Nortel Phone System Tech Support
This says that the mailbox must be initialized.
http://www.uniquecomm.com/docs/Startalk_Flash_Quick_Reference_Guide.pdf
Oct 06, 2014 | NorStar Lands Phones
Nortel t7316e
Hi D,
You should go into your voice mail and check your Outdial settings. If Outdial is turned on, you`ll need to deactivate call forward from there.
Sep 06, 2013 | Nortel Norstar 16-Line PBX Speakerphone
Admin nortel i can't access the adminstrative programming. i enter feature 983 and it says "inactive feature". how can i fix it to where i can set up a new mailbox?
If you are getting inactive feature when entering feature 983 the phone system and voice mail unit are not communicating. This usually requires a power reset to clear. Or the voice mail unit is in trouble and a vendor needs to be called.
Aug 12, 2013 | NorStar T7316E Corded Phone
How can I activate feature 981
Press FEATURE (above the HOLD key on old sets or the Nortel Symbol on the new sets)
Then press 981 on the dial pad.
If states "Inactive when done then your voice mail system is down or the feature code was changed, either way if you do have voice mail then call your tech in to check the system right away.
Dec 19, 2012 | NorStar T7316E Corded Phone
How do I listen to by mesasges on a Nortel T7208
To access your voice mail messages either press your open voice mail key (if programmed) or enter feature 981.
Dec 11, 2009 | NorStar T7208 Corded Phone
How do i retrieve calls on my nortel norstar telephone from my home phone?
To access your voice mail remotely, while a greeting is playing (either the mail greeting or your own mail box greeting) press ** followed by your mail box number, password followed by the # ( ex. **,221,1234,#).
Oct 20, 2009 | NorStar T7208 Corded Phone
Change voice message on nortel meridian phone system
You need to go in to voice mail admin .
Feature 983 1020000
press AA
press Greeting
press greeting again
enter 1 for greeting 1
this should be your main greeting it could any greeting from 1- 20 , it depends on how it was set up but that should work fine .
Feb 17, 2009 | Nortel Norstar 16-Line PBX Speakerphone
Nortel T7316E
To reset passwords for Feature 983 do the following
Press Feature 985
Press 9
Enter 73738767793
Press OK
Now go back to Feature 983
Enter 120000 for 2-digit extensions, 1020000 for 3-digit or 10020000 for 4-digit
Aug 21, 2007 | NorStar T7316E Corded Phone
Norstar Mailbox Problem
The mailboxes don't need to have saved messages, to be full. More then likely what is happening is that when people call in, they are getting a generic/Auto Attendant vm box, and that one is full. Try checking vm box #100, or #10. That is the Nortel standard general delivery vm box. Please let me know is this helps, or if you more help.
May 25, 2007 | NorStar M7310 Corded Phone
NorStar M7324 Telephone Logo
57 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
pbxinc
syaiful ridlo
syaiful ridlo
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
